Lake Country Pad Choices
Old Aug 11, 2009 | 12:56 PM
midlife chrysler's Avatar
Default Lake Country Pad Choices
Hi Folks, well, I've decideed to bite the bullet and buy the 7424XP. I get my choice of three Lake Country pads with this kit. Since I don't know the first thing about it, what should I take as my pads??
Thanks, Brian
Old Aug 11, 2009 | 01:21 PM
Jake80's Avatar
Default Re: Lake Country Pad Choices
I buy products from Classic Motoring in Florida. You can find them if you do a search.
They have details on pads and description of what each does. As an example I have one that is orange in color for applying product like scratchX or all in one cleaner product. The next pad is yellow where I apply the polish coat and the last pad I have is white. I use this to apply sealer or carbuna wax finish. I think I got the color correct. Again go to the site and they explain the type of pads/applications.
Jake80
Old Aug 11, 2009 | 02:51 PM
From the Lake Country website I downloaded a Pad Application Guide. The key is in being able to judge what level of scratching/ oxidation you want to remove. Being conservative, I might be looking at white, followed by black, ending at blue pads...now I need to figure out what products I'll need!
http://www.lakecountrymfg.com/applic...tion-guide.pdf
Old Aug 11, 2009 | 03:07 PM
Jake80's Avatar
There are alot of products out there and each has his own favorite.
I know that PatP on the forum uses Zaino products and his car looks great. I plan to order some and see if I can improve on my finish.
Best of luck.
Jake80
Old Aug 11, 2009 | 04:09 PM
GDC-SRT's Avatar
I use lake pads, and pinnacle polishes. I am sure Meguiar's would work well also
your choice of pads should work well.
Old Aug 11, 2009 | 04:39 PM
Thanks, guys. Sorry to be so thick, but what sorts of products am I looking for? Is it three different things for the three different pads, or a buffing compound and a wax? I have a red '05 that looks pretty good, just want to make it as nice as possible and maintain it.
Old Aug 11, 2009 | 04:55 PM
GDC-SRT's Avatar
Depends on paint condition, If you have heavy swirl marks, use a light swirl mark remover, with the white pad. Followed with polishing glaze on the black or blue.
Then I wax by hand.
I always start with the least abrasive product, then go heavier if I need to.
Here are some good tips.
Auto Detailing Facts, auto detailing Tips, How to detailing Guides, how to polish, how to wax, DIY detailing, do it yourself guides
Old Aug 11, 2009 | 06:13 PM
H82BL8's Avatar
Check out Golfdudes sticky also:
https://www.crossfireforum.org/forum...crossfire.html
I always start with an LC orange pad and work softer with the glaze, sealer then wax. Our Crossfire's have very hard clear-coat. This vehicle demands more aggressive techniques to remove swirls because soft pads will not have an effect on the clear-coat. Make sure to test in a small area first. If its not working you can use a more aggressive pad or compound. A kit with an orange, white, black, and blue pads should get you started.
Make sure your 7424XP kit has a Hook & Loop Backing Plate, you'll need it to attach the pads.
Old Aug 11, 2009 | 06:17 PM
White, black, blue and gold. Stick to the foam pads and use the per the guidelines you posted.
Old Aug 11, 2009 | 07:19 PM
32krazy!'s Avatar
try the new lake county kompressor pads. they work very well
as for zaino products they are not really formulated for a buffer. it can be used but the products are designed for hand use
chturner
19
Oct 14, 2019 04:42 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
steps
Oct 13, 2015 06:18 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ritous1
Sep 26, 2015 01:27 PM
