winterizing virgin
Old Aug 31, 2009 | 08:14 PM
cassidyrj1's Avatar
Default winterizing virgin
Hey guys winter is getting closer and closer and it's my first winter with the srt. I have never winterized a car. Any of you guys have some good tips on what to do like do I put it on jack stands? Is there anything I put in the gas? I know nothing so any info would be very helpful.
Old Aug 31, 2009 | 08:35 PM
old man's Avatar
Default Re: winterizing virgin
move to FL an drive it all year
Old Sep 1, 2009 | 07:49 AM
cassidyrj1's Avatar
Haha I was in florida last year for school with the car. I didn't like it down there to much thats why I am back up in new york. Plus i have a little beater truck for the winter that i cant wait to drive.
Old Sep 1, 2009 | 09:50 AM
ravery's Avatar
Bring your car to my place in Johnson City and I'll take care of it for you. I promise.
Old Sep 2, 2009 | 11:33 AM
LugNut's Avatar
I'm not planning to put mine on blocks, but I will likely start-up and move it a bit every month or so.
I recently changed the oil and filter, but in future years will likely change it just before storage.
And store with a full tank of gas. Opinions on using a fuel saver additive (like Sta-Bil)?
I'm planning to replace the fuel filter over the winter.
The battery concerns me most. I don't want to disconnect it, and I need my cheapo float-charger for elsewhere too. So starting to look at better ones, with pig-tail leads to attach permanently.
Already picked up a cheapo car cover (~$30) at WM. Car will be clean and very dry before storing.
And, of course, will check the antifreeze for low-temp capacity.
Old Sep 2, 2009 | 11:37 AM
patpur's Avatar
Senior Member/Moderator
Beware of mice! Seriously.
Old Sep 2, 2009 | 02:38 PM
waldig's Avatar
Talking Re: winterizing virgin
If stored in a garage you might add some moth ***** around the tires or better yet get mouse pellets, they like insulation and padding. >>>>>>>>>>>>Not to be placed inside<<<<<<<<<<<<<<<<<
Best value I have found is the 2 amp battery float charger, NOT a battery charger. Available at walmart for about 18.88$ recently. I test each one I have bought for all 6 vehicles and riding things and the OPEN CIRCUIT voltage was always like 13.6 - 14.0 with limited energy so you wont bake the battery. Harbor freight has useful multimeters for checking these sort of things on sale for $2.99 and includes a durn backlight that my Flukes dont have.
Had a little skid loader that lost a battery every winter before, now its still perky after about 4 years of battery tender maintenence.
Woody
PS. I have done a fair amount of testing of the "battery desulphator units" SHOWN and have not been to detect any improvement or benefit over the Much Less costly tenders..
THe 440 shown has a pigtail that pops off without opening the trunk and it is an added benefit if you get going without remembering that your teather to the battery was NOT disconnected.
I designed and added an accumulator to the 10 Quart oil system to my Challenger so I always start with oil pressure before cranking the key over. Sitting causes drain-down and that is tough on a HIGH compression toy after the winter or a long quiet spell..WW
Old Sep 2, 2009 | 02:50 PM
LugNut's Avatar
No problems with mice, only a six foot long snake once. He's wasn't a problem for long.
Old Sep 2, 2009 | 04:32 PM
cassidyrj1's Avatar
Thanks guys i really appreciate this. Now I just have to find a place to put it.
Old Sep 2, 2009 | 05:52 PM
sonoronos's Avatar
What's wrong with disconnecting and removing the battery?
It will probably save you in the long run.
Old Sep 2, 2009 | 06:26 PM
LugNut's Avatar
"What's wrong with disconnecting and removing the battery?"
Lose all my programs, and the alarm system.
Old Sep 2, 2009 | 07:02 PM
dwightdmagee's Avatar
Banned
.....Feel free to put it in my garage in Sarasota if you'd like. No ice. No mice. No problem.
Old Sep 2, 2009 | 07:19 PM
LugNut's Avatar
"No problem."
Just be sure to leave a set of keys with you?
Old Sep 4, 2009 | 10:32 PM
Goldwing's Avatar
Michigan winters are long and hard, and I've stored my roadster for 4 of them and the SRT6 for 1. Waldig gives good advice. You can also buy float chargers at Harbor Freight for about $6/each, but with shipping it's better to buy 2-3.
Give it a good washing. Put in the recommended amount of Sta-Bil and a bottle of gas line antifreeze, then fill it. Fill the tires up to recommended pressure +2 lbs. Buy a cheap cover from Walmart to keep the dust off it. Last winter I used a self-store place and could only get the cars started once and drove them around the lot once. This year it's back to my garage and I'll probably start them every 4-6 weeks. In the self-store I put sticky boards along the walls and two boxes of moth ***** on the floor - no problems with vermin. Moving the cars -- drive them around the block if the roads are dry/salt-free, reduces the flat spots.
Old Sep 6, 2009 | 04:29 PM
cassidyrj1's Avatar
Well the problem i have is that i am not going to be able to drive it any where. Our driveway is a dirt hill that is about a 1/4 mile long. So i thought about taking off the tires to clean everything and putting the car up on jack stands. Also i thought of an idea for the mice. I am going to get two small car covers from the parts store and sew them together and then put a zipper on one end to make a big sleeping bag for my car. I hope that will keep the mice from getting in.
Old Oct 12, 2010 | 05:25 PM
IBLUBYU's Avatar
I'm not a Winterizing Virgin, but I'd like to add one more thing to the list ....... I shove 2 tennis ***** into the exhaust pipes to prevent any mice from seeking refuge, along with the sticky traps and moth ***** around the car. Anything to add?
Old Oct 13, 2010 | 10:33 AM
Hawk Monster's Avatar
I put a couple of silica bags in the trunk and in the passenger's side to make sure no water vapor is allowed to accumulate. I change these every couple of months. I also soak two sponges with leather cleaner that has a leather odor to them. In addition, I put the car on plywood that is covered with carpet pieces. I use sta-bil and replace my oil and filter just before their long winters nap. Needless to say they get a total detail before storage. My garage is heated so I keep the temp at 50 degrees. On the roadster, I put a blanket on the top before the car cover. Since I only drive in good weather I put the top up for the winter storage. I also use the battery tender mentioned earlier. I also replace my brake fluid. Most important take them for a long drive before storage.
P.S. I take the antenna off the roadster.
Old Oct 13, 2010 | 11:29 AM
patpur's Avatar
Mice will eat through your car covers. I have living proof. Make sure you follow IBLUBYU advise about the tennis *****, they can cause some real problems.
Old Oct 13, 2010 | 11:34 AM
maxcichon's Avatar
Ultrasonic pest repeller. Assuming you have 115VAC where you are storing it.
Amazon.com: Bell + Howell Electromagnetic Ultrasonic Pest Repeller: Health & Personal Care
Bird-X Transonic Pro Ultrasonic All Pest Repeller - TXPROX at The Home Depot
These things actually work. Not like the "Ultrasonic Whistles" for deer you stick to your front bumpers!
Old Oct 13, 2010 | 12:47 PM
midlife chrysler's Avatar
I've had one winter with my coupe and my $.02 is that you need the float charger for sure, not just to save the battery but to avoid those annoying alarm problems. I put fuel stabilizer in but got a light on the dash the next time I ran it, don't know what that was about. Anyway, that part of it seemed to clear up after a little bit. I didn't do anything else and have not noticed any problems, as yet.
