Chrysler 3.5 V6 motor
  #81 (permalink)
Old 03-13-2011, 02:52 PM
thummmper's Avatar
Default Re: Chrysler 3.5 V6 motor
the right arm is off the van and I have started cutting it and removing the drum hub. its greasy and wax coated, so I may take it to school tomorrow and put it in the autowash. this project is showing me what i'm made of--and it feels like mush right now. I am addicted to results, and there are too many open items working -- I just put the van on stands for the suspension fit and the fuel tank work, along with the wire routing.
  #82 (permalink)
Old 03-16-2011, 01:25 AM
thummmper's Avatar
the autowash is just great--6 pressure heads and a rotating cage. only a bit of wax inside remains. Ive been detained with studying for my mid term in auto electronix--- I can give it hell again after school tomorrow--
I was scared to death that I was dropping my hands with this project, but I'm just curious as to how she will drive--I just have to buy some more patience
  #83 (permalink)
Old 03-19-2011, 12:15 PM
thummmper's Avatar
comparing the two rear suspension arms [vanagon and bmw 735i]
  #84 (permalink)
Old 03-22-2011, 08:10 PM
thummmper's Avatar
the rear calipers got their due today--apart, cleaned and painted along with the lr arm for tomorrow's install.
  #85 (permalink)
Old 03-23-2011, 09:29 PM
thummmper's Avatar
halfway done with the rear brakes, gents
and it's installed, although it's hard to believe that this nasty hub
is now this
and the drive hubs are in place as well, so it will be a length of halfshaft game now...
the shocks will be replaced with bilstein monotube HDs
  #86 (permalink)
Old 03-24-2011, 08:47 AM
tunaglove's Avatar
Still paying attention.
  #87 (permalink)
Old 03-29-2011, 08:28 PM
thummmper's Avatar
The dash mod resumes--I need to install the LHS column, brake switch, range selector and lockout and the cluster, so the LHS dash may work in there.
  #88 (permalink)
Old 04-01-2011, 01:04 PM
thummmper's Avatar
I took the pad cap off the vw dash and rehung it with 2 screws for the prefit. the steer shaft needs shortening at the floor enough to include the chrysler u joint. I may just cut the lid off and add around it.
  #89 (permalink)
Old 04-03-2011, 08:16 PM
thummmper's Avatar
the trimming has begun--the column aligns up nicely with minor adjustments
and the cluster [LHS] sits aft too far into the wheel area
  #90 (permalink)
Old 04-05-2011, 09:30 PM
thummmper's Avatar
the LHS steer column is in, now that I have decided on its attitude
  #91 (permalink)
Old 04-06-2011, 10:28 AM
thummmper's Avatar
  #92 (permalink)
Old 04-07-2011, 08:23 PM
thummmper's Avatar
fitting #4--the range selector lockout cable must loop to the ign sw through the blower housing or...
  #93 (permalink)
Old 04-08-2011, 05:15 PM
thummmper's Avatar
fit #5 cluster is in its final locale. headlight sw also. facia is set as well
  #94 (permalink)
Old 04-10-2011, 12:06 AM
thummmper's Avatar
fitting #6-- the upper right storage box on the dash
  #95 (permalink)
Old 04-13-2011, 11:19 AM
thummmper's Avatar
  #96 (permalink)
Old 04-13-2011, 09:25 PM
thummmper's Avatar
  #97 (permalink)
Old 04-14-2011, 08:19 PM
thummmper's Avatar
final weldup and paint prep
  #98 (permalink)
Old 04-15-2011, 10:18 PM
thummmper's Avatar
primed and some ss tubing for fun
  #99 (permalink)
Old 04-22-2011, 11:02 AM
thummmper's Avatar
went a junking for an extra shifter cable to plunge the connections under the floor for a strait connection from both ends [shifter and trans]
got some nice wheels for the project from a friend--mbz ronal 7.5 x 16 x et 46mm.
  #100 (permalink)
Old 04-22-2011, 11:36 PM
thummmper's Avatar
the final fitting with the column, and the shifter mockup
Quick Reply: Chrysler 3.5 V6 motor
