Turbo kit proposal, help with your ideas please!
Originally Posted by Maxwell
Yes I realize that, It takes a long time to find a relatively economically priced ecu, that has quality features. I'm not interested in a tuning-pot box either as that's just cheesy. HKS or maybe Greddy has something worth it's salt, I really want laptop control and the ability to advance timing, as this is a feature not available on some cheaper units. so, I'm still looking to see what's out there.
Check this out, this looks more promising http://www.bosch-motorsport.de/pdf/ecus/MS_4_Sport.pdf.
It even has Traction control port. and electronic flyby wire throttle.
http://www.bosch-motorsport.de/conte.../html/2953.htm
This will go nicely with the whole set-up. Only 125 eur. http://www.bosch-motorsport.de/pdf/displays/DDU_4.pdf
The MSD Dashhawk looks to be a similar monitor with a much lower price point - $300. I want to get one of these real soon.
If that turbo kit works good for a standard 6 speed Xfire, you could pick up a low miles '04 - '05 and really get it rockin for cheap. Keep posting updates. Would need suspension mods to keep it up with the SRT6, but hey, and extra 70 HP or so would really help the standard Xfire. Heavy car, needs a bit more punch.
Originally Posted by JP@SI
FYI Speed Innovation in 30 days will be able to engineer, fabricate, and tune a turbo kit for crossfire all in our new faculty. Pm for more details.
Do your best to keep cost down without making it cheap quality, it just needs to be reliable and make at least another 60 hp I wonder if it's possible to fit an intercooler under our hood somewhere? I figure at 6 psi we would gain about 40% more power.
Who's car will you be using for the design phase?
did Status move out of Hermosa or you and Jesse just changed shops? where are you guys now?
also, there's someone here who's manufacturing headers for the srt6. i suggested to them to partner with you guys so SI can do the ecu tune to produce max results out of them.
once they're available, i'll get em and i'll give you guys a buzz... later.
what happened here??? all the wonderfully optimistic talk of turbos its like getting high the thought of hearing my blow off valve over my system awww ... darn now there is a wet sticky spot in my pants thanks a lot.
Big Daddy
Sep 10, 2015 10:21 PM
