Is this the dreaded intercooler leak?
Old Dec 20, 2010 | 04:21 PM
Default Re: Is this the dreaded intercooler leak?
Originally Posted by velociabstract
My car thinks 70º is freezing! I don't think cold has anything to do with it. If I had to make a guess it would be from sitting for 2 years or a manufacturing defect. I'd hate to buy a new intercooler then discover I don't need one once the car is apart; but it would be worse to get the car apart and need one without having one ready to go. I haven't checked my heat exchanger level for a few months so I'll do it and report back later.
I have a Needswings catch can installed for over a year. When I installed it I didn't see any crud in the manifolds.
Les
Then I would say you have a problem Les...
Old Dec 20, 2010 | 04:32 PM
velociabstract's Avatar
Houston, Les has a problem ...... I repeat Houston, Les has a problem. Should I activate the landing sequence or give your engineers a crack at the problem. Houston ..... are you there? Houston, we have contact with the green alien substance. How would you like to proceed, live and let live or extermination. Please confirm Houston.
Les
Old Dec 20, 2010 | 05:10 PM
rcompart's Avatar
Les
Hope everything is alright Les. It's just an IC leak, no need to go crazy just yet.
Old Dec 20, 2010 | 05:15 PM
Wow....it wasn't a big problem....you didn't have to start drinking yet....that comes once you have the SC off...then you start drinking... Check out that avatar Rudy....and you thought I wouldn't get them out when it was snowing.....there you go....Les...you could be living in these conditions...so fix the damn leak....lol
Old Dec 20, 2010 | 05:32 PM
Guran's Avatar
Opinions needed. This is my old Y pipe which I replaced today. The intake manifolds looked clean to me but the entrance to and Y pipe itself had a lava floe of this stuff. It has some green color mixed in. So, is it time to go looking for a replacement intercooler?
Les
Try Holts RadWeld. It has worked for me in 3 years.
My whole intake manifold was clogged with 1 cm slime.
Cooling Repair Systems :: Repair & Maintenance :: Holts Auto
/Göran
Old Dec 26, 2010 | 05:05 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Les,
What was the outcome of the green sludge?
Old Dec 26, 2010 | 05:15 PM
Rudy didn't answer my PM! The leak is minor so I decided not to get in too big a hurry. I'd love to get a new one, and most likely will, and from Rudy if possible. It may be costing me some power but I don't see it hurting anything in the short run. When the time comes I plan on doing some porting at the same time. I mean, if it all has to come off, it's a no brainer. I'm hitting the books and finding all the tools so I can do it myself. Well, if the business improves I'll pay an expert but things still look grim in my neck of the woods. So DIY rules!
Les
Old Jan 8, 2011 | 02:23 PM
I went to top off my supercooler today and guess what. It was full! Every distilled drop I tried to put in ended up on the ground. Now I'm wondering where that crud came from. I have a Needswings catch can, and it's working BTW. Not huge amounts of oil is collected but always some. When I cleaned the filters I oiled them pretty heavily but???? The throttle body was clean. Now I don't think it's the intercooler. Who can solve the riddle?
Les
Old Jan 8, 2011 | 04:45 PM
rcompart's Avatar
Les
You need to pressure test it. It may be such a small hole that under normal circumstances it doesn't leak but remember that our cooling system is pressurized so test it at 10psi and then report back. Easiest way to do this is take the IC and fill it with water mixed with red food coloring and then put a white paper towel in the openings. Set it so the coolant inlet and outlet are facing up and the paper towel in the bottom where it connects to the Y-pipe. test it with 10psi for 24 hours and if the rag is red, you know definitvely that your core is leaking. If it's not, then perhaps it's just blow-by.
Good luck
Old Jan 8, 2011 | 05:07 PM
I separated the cooling system from the intercooler a year ago. My thinking is it was leaking while stock but now that it's separated from the pressure perhaps I'm OK. I'll pull the Y-pipe again after another 1000 miles and decide whether to disassemble the system and test it based on what it contains.
Les
minimayhem
16
Aug 23, 2016 07:47 AM
debradegiovanni
Sep 27, 2015 09:39 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
RacerXofFL
Sep 15, 2015 05:00 PM
williammt
Sep 6, 2015 11:23 AM
