egr valve
wonder if anyone can help me i have a uk 2004 xfire i think i need to replace the egr valve but i need help locating it and i wanna know if its an easy job to replace it and could i replace it myself.
Download the 2005_Crossfire_SRT6_Service_manual.pdf ( you can find it elsewhere on this forum ).
Check section 25-26
Crossfire SRT6 Documentation Collection
( I know it says 'SRT6', but mostly applies to all. )
Check section 25-26
Not 100% sure it needs replacing yet just got problems when the engine cold and i start it up it smokes loads and popping noises come from exhaust and feels like sometimes the car is pulling back in low gears
I checked your prior posts and I found your initial post and the previous replies.
Do you have any codes set in memory? Your answer may lie there.
OK, my EGR did need replacing as it threw a code (which? I forget). On one of a rubber hoses connected to it there's a black cap that doesn't seem to go anywhere.
Question ... does it connect to anything?
Your description sounds accurate. The cap was tucked down out of site. The replacement is an exact match of the original. I've attached a couple of pics. I'm hoping it a breather.
What symptoms did you have if any, that made you replace the EGR valve?
I'd still be interested in what that cap is
I had no (real) symptoms. I took the car to the stealer for an oil change. I mentioned it had stalled on me a few times and threw a CEL. Turned out it was the CPS and they also said I needed a new EGR ... all for the low low price of $998.00. That's how I stumbled upon the forum (while looking for parts).
It is amazing how stealerships can find you need parts that you did not know you needed.
Stay on this forum and you will save money.
You're a funny guy! Once I found the forum and saw by doing those two repairs myself I would save $800+, I looked at ways to spend the savings ... (DCAI 1st) ... haven't stopped spending and having a blast!
You're right, it is a Check valve and goes nowhere. I've had my egr off several times and it is a snap. For future reference, you need to unbolt the fuel rail and pull up the passenger side slightly to get to one bolt. In fact, the hole thing is easier if you pull the closest injector (the connector at bare minimum) Other than that, a crescent wrench for the egr tube, 2 bolts, and you're done!
tritongreen
Sep 18, 2015 07:32 AM
