Cold air intake with stock cover?
Old Oct 12, 2011 | 04:22 PM
Pat13's Avatar
Question Re: Cold air intake with stock cover?
how did u get the pipes throught the radiator support? Im doing it now and ive just removed the plastic restriction but i measured it and it not even 2.5 inches. Do i need to get a flexible hose or something ? if so please post a link or picture of what it looks like(the hose that can run past the radiator support, 3in diameter). Im really pissed i just received that double bent pipe that matches our stock tube shape but theres no way i can run that through the radiator support hole. A little help please...
Old Nov 26, 2011 | 05:40 PM
deltacrossfirebob's Avatar
Default Re: Cold air intake with stock cover?
ok, whar went best??
the max-redline parts or the other??
i have my devil horns from rob and am looking to do the best install.
appreciate both your inputs.
also did 74tb but not the maf change.
thanks
Old Nov 26, 2011 | 07:29 PM
dtinker's Avatar
I put the 2.75" tubes on, I had to bend them out of round to get them through the radiator support. I made some tubing ' Devil Horns", not quite the same but go through ok. I insulated the tubes, but think I'm going to insulate the bottom of the air box too.
waldig
Sep 2, 2015 11:02 AM
itsky
Aug 4, 2015 10:35 PM
waldig
Jul 30, 2015 07:39 PM
waldig
Jul 29, 2015 06:54 AM
waldig
Jul 20, 2015 08:10 AM
