Some good stuff on oil aeration, and what to watch for
Old Dec 7, 2011 | 08:41 PM
cudaman's Avatar
Default Some good stuff on oil aeration, and what to watch for
really good article from MIT. Shows the amount of aeration, which is apparently linear, and affects of engine speed, oil pressure, return lines, and windage trays.
http://dspace.mit.edu/bitstream/hand.../166145859.pdf
Pages 14-17 show the math and how temp,pressure,engine speed bump the %aeration.
So, keep your eyes on that "HI" oil indicator display that appears if you overfill the crankcase.... Over time, it could cause more problems than you think
SAE has a "paid" article too.... Wasn't worth it. If someone with a built engine and hi RPM redline and a windage tray wants to double check aeration factors, and measurement, might be worth it.
Have to pay for it though.
Method for Prediction of Engine Oil Aeration Rate
Old Dec 7, 2011 | 08:57 PM
6000rpm's Avatar
Default Re: Some good stuff on oil aeration, and what to watch for
That will be good info to read. It's the kind of stuff they talk about on bobistheoilguy.com
Thanks for posting.
PNA
Nov 12, 2020 04:44 PM
4drturbo
Jan 3, 2019 02:46 PM
jgreen
106
Sep 18, 2017 11:46 PM
hhr hellshotrod
Aug 17, 2015 11:27 PM
xzmilan
Jul 22, 2015 10:40 AM
