xfire SuperChip
Old Jan 19, 2005 | 02:50 PM
EUROREV's Avatar
Default Re: xfire SuperChip
Long distance can be done if you ship the ecu to us we will turn it around the same day we recieved a bit extra if you want overnighted back to you We have many customers that send us their control units if you decide to send it to us please insure it as we will do the same.
I know there is alot of chip manufactures out there but for the price and for the customers that have already recieved the upgrade software everyone is happy. 1000 dollars for a xfire ecu is crazy even at 600 its still up there
Old Jan 25, 2005 | 01:35 PM
christo76's Avatar
what exactly does the chip do? any downsides, or long term effects?
Old Jan 27, 2005 | 02:36 PM
911split's Avatar
Who did the software for the EUROREV chips? Is it in-house?
How does EUROREV's differ from Upsolute or SuperChip?
There are a lot of different chips being offered out there. What are the differences between them? Are they all offering the same thing, just with different labels printed on them?
What are the drawbacks or dangers to chipping a XF? Could the software possibly enable us XF driver's to damage our cars?
I've heard that chipping wil kill our warranties. I've also heard that the only way for the dealer to tell your XF has been chipped, is if you tell them. Is this true?
If chipping is so safe and you get all these great benefits (more hp, improved acceleration response, increased gas mileage...), then why isn't it approved by the dealer? Why doesn't Chrysler offer it? What makes is so bad to Chrysler?
Old Jan 27, 2005 | 03:02 PM
english_bob's Avatar
I had the Upsolute chip fitted at around 3,500 miles. My car was serviced yesterday at 12,600 miles as indicated by the dash. The dealer did not detect the chip.
DC do not chip engines as the change to the profile does reduce engine life by 3-5%, or for MB engines from around 330,000 miles to around 315,000 miles, and there may be reliability issues with the chipped profile long-term, as the red-line is moved to about 6,200 rpm. Chipping basically eats into some of MBs tolerances for an engine.
I get better power profile across the rev range, it is noticeably quicker, I get 2-3mpg better fuel consumption, and I can easily cruise in 6th from 22mph.
Probably the best £305 I ever spent.
Old Jan 27, 2005 | 04:20 PM
AlvinByars's Avatar
911split,
When tuners flash the ROM (normally, Read Only Memory, except when being flashed) in the Powertrain Control Unit (PCU, aka ECU, ECM, etc.), they are poking (writing) new values into the various tables that are contained in the ROM. These tables contain the values for ignition advance, fuel/air mixture, etc. for various loads, engine RPM and throttle position. Ideally, the values that are poked are determined on a dyno with your car and the specific equipment/mods on your engine. If the values for your car are not determined on a dyno, then assuming that your engine is stock, they poke values for a typical stock engine for your make and model. These values may or may not have been determined on a dyno. If they were not determined on a dyno, then the tuners use typical values based on similar engines. These values are probably "close enough", given that the tuner is somewhat conservative in the values that he is using. If you have made mods to your engine (headers, exhaust, larger injectors, forced induction, etc.) and the values are not determined with your car on a dyno, then the tuner will use typical values for comparable mods. Again, these values are probably close enough, given that the tuner is fairly conservative. The values used by different tuners will vary slightly depending on how conservative the tuner feels he should be. As with other components for your car, the cost depends on what the market will bear, given "brand appeal", the reputation of the tuner, etc.
The drawbacks, dangers and risk of damage to your car depend on the values that the tuner pokes into the tables. Potential damage could be caused by too lean air/fuel mixtures, ignition too far advanced, or (if the rev limit of the engine has been raised) over-revving the engine. However, most reputable tuners will use values that are conservative enough so that the likelihood of damage to your engine is very small. Doing something that is likely to damage your engine is not going to help the tuner stay in business, and most tuners are concerned about their reputations and are in business for the long haul.
A manufacturer cannot void your warranty because you had your PCU flashed by a tuner. However, if damage occurs to your engine, and if the manufacturer/dealer suspects that the damage may have been caused by alterations to the table values in the PCU, and if the manufacturer/dealer can “prove” that your PCU was altered, and if he can prove that the altered values were responsible for the damage, then he can refuse to pay for the damage. Although it is very unlikely that the dealer will try to peek (read) the table values in your PCU during normal maintenance or repairs, it is not true that he can’t do so. If you can poke ROM, you can peek ROM.
Regarding the benefits of altering your PCU, it just depends on how conservative the manufacturer was when he developed the initial values. Traditionally, MB is not all that conservative, so the amount of horsepower/torque increases that you get by altering your PCU may not be as great as with some other manufacturers. However, from what I have read from forum members who have altered their PCUs in the Crossfire, you can expect increased throttle response, some increase in horsepower/torque, smoother power curves, and slightly better fuel economy. It is not necessarily true that reliability and durability of the engine will be compromised. That depends more on how you drive and maintain the car.
And it is likely that DaimlerChrysler will eventually provide an upgraded PCU for the Crossfire. Mopar (Chrysler’s performance unit) offers upgraded PCUs for most of their other other makes and models, and (with the exception of the high performance racing PCU for the Viper) all of these upgraded PCUs are included in the manufacturer’s warranty.
I hope this helps.
Old Jan 27, 2005 | 08:13 PM
bornfeld1's Avatar
I have the upsolute chip in my 05 roadster. The car is much faster and more responsive
Old Jan 28, 2005 | 12:52 AM
911split's Avatar
Thanks english_bob and AlvinByars. Very informative. I feel like i got a handle on chipping now.
Anyone know how long it took Chrysler to offer a PCU upgrade for other models? It'd give us a ballpark timeframe of when to expect a Crossfire PCU upgrade by Chrysler.
Thanks.
Old Jan 29, 2005 | 06:00 AM
Christopher Barker's Avatar
English Bob -
How do you know that "The dealer did not detect the chip"?
Old Jan 29, 2005 | 02:25 PM
Originally Posted by Christopher Barker
English Bob -
I guess that I don't for sure. It would be more correct for me to say that the dealer did not mention the chip. They certainly didn't reflash it, as it still redlines to just over 6200-6300ish.
Blackktieguy
21
Oct 26, 2015 12:32 AM
xfireon20z
Sep 10, 2015 04:27 PM
Caught in a Xfire
Sep 5, 2015 05:20 PM
Caught in a Xfire
Sep 4, 2015 10:14 AM
Crossfireone
23
Aug 25, 2015 04:56 AM
