Secondary Cat removal advice
Old Jan 18, 2016 | 12:49 PM
c44588's Avatar
Default Re: Secondary Cat removal advice
Question, if one was to delete rear cats on a N/A Xfire Coupe Ltd., and replace with the referenced SS X-Pipe,...
X-Pipes - Mandrel Bending Solutions
...would you still use the 2.25" diameter, and does the standard stock exhaust pipe fit Inside the X-Pipe diameter (inserting into the X-Pipe) or Outside (sliding over the outside of the X-Pipe)? And which clamps are recommended?
Thanks guys!
Old Jan 19, 2016 | 10:38 PM
Sweet2002's Avatar
My SLK32 AMG will have a magnaflow TRU internal X-pioe replace the rear cats to help balance the odd V6 exhaust pulses with a "Y" connecting the dual exit magnaflow, no resonator with a 3" pipe leading to a borla pro XS muffler, Borla's do not drone nor do the hookers. Good luck
onehundred80
Aug 6, 2016 12:03 PM
smokey847
Nov 12, 2015 11:54 PM
81's
Sep 13, 2015 04:34 PM
Sep 13, 2015 02:12 AM
jaesa
Sep 7, 2015 01:50 PM
