Bulb Replacement
Alright guys, my turn to get pissed. I'm trying to replace the front left low beam and all the threads and manual say just pull the electrical connect off the back of the bulb...then do the clip thing...
I can't get the connector off the back of the bulb! won't budge...i'm afraid to yank too hard on the connector as i don't want to bend that clip wire...
Any advice?
I have no problems reaching it...
Help!
Any advice?
Help!
ron,
i can see the clip, the point was that you have to remove the black electric connector first, remove it, so the clip swings out of the way to remove the bulb...
i can't get the connector loose.
it won't budge.
it won't budge.
Thanks Ash for assuring me its not just a Senna brain fade...i know your right...but god damn it...
Freakin thing...there's going to be blood spilled on this one...
Well cleaned up the blood...but Ash...thanks again for the inspiration...it finally popped off...hit my hand on the edge...bled a bit.
Holy cow, i'm only glad it wasn't the right side...anyone had to replace that? How do you get your hand in there...or has someone removed the windshield washer fluid tank?
DONE
DONE
Any advice?
Help!
Any advice?
Help!
ron,
it won't budge.
it won't budge.
I just got finished changing my low beam bulbs and the whole operation took maybe 15-20 minutes. WHY? Because of all the previous postings on this thread. Thanks to everybody who put their hard won wisdom down in print for the rest of us.
A couple of other thoughts for non-mechanics like myself.
- Look at the drawings in the service manual.
- The retaining clip is "V" shaped and hinged at the wide end.
- The small end is held down by a hook on the headlight housing, push down and away to free it and swing the clip up to release the bulb.
- Do not squeeze the wide end or the whole damn clip will come out.
Originally Posted by FlaRon
Thanks. I did download a Service information sheet that has pictures of how that bail wire attaches. I am sure the second one will be easier than the first.
The foglights are a complete unit - you access them from small access panels behind the front bumper - right in front of the front wheels.
There are 2 type of foglight - original (chrome bit kept falling off), and the revamped ones. - do a search, there are pics of both somewhere.
Search for the service manual on this site, and all will be revealed.
The service manual and others is here: https://www.crossfireforum.org/forum...ad.php?t=13875
Before I open up the left lowbeam holder to replace, want to make sure I have right bulb. It's the H7 (Sylvania is what I bought). 55 Watt designation.
Also, I'm assuming bulbs and their replacement are NOT covered under our Chrysler warranties, right?
Thanks!
Thanks!
Next question. Haven't seen this addressed in the thread yet. There is an aprox. 5X4X1 inch power module in the way of the left/drivers side low beam headlamp access. It has 2 mounting studs/nuts and a large electrical connector. Is there any known problem with removing the big connector to gain access to one of the module's mounting nuts? Don't want to "reset" anything by removing the connector. This connector has 4 large #4? leads and 2 #18? leads. It is right in the way of access to the left low beam bulb comparment.
Anyone removed that module before replaceing the bulb?
Thanks!
Thanks!
Thanks!
Thanks!
I just bought an '04 CF. What fun. I noticed right headlight out of adjustment. Removed rubber cover and previous owner had lost the wire clip and held the bulb in with cardboard. Any ideas where to get a clip?
I tried to download the service manual and got an error. Any ideas.
What a great web site!!
Originally Posted by FP
For the Roadster; Pull off fasteners that keep the side panels on in the trunk. I think there are about 4 or 5. Pull off the side panels/carpeting, and you will have access to the tail lights.
