Access to the Fog light power?
I have a 2005 Coupe that came without fog lights. I've got some aftermarket ones installed but can't find where to hook them up. I put in the missing fuse and now the panel light comes on so I know I've got power up to the switch. There are no extra wires on the harness that goes to the lights either.
normally you access them from the inside of the front wheel well area. easier if you turn the front wheel completely. there is a plastic cover you need to remove to access the back of the bulb. (see pics).
being yours is a base version... they may have used a different plastic wheel well housing.
you will have to wire them in the base version... no harness provided.
Adrian_X
Nov 9, 2017 08:49 AM
KwehCat
Jul 16, 2015 04:48 PM
