Want to add Fog Lights to Base Roadster
Old Apr 4, 2007 | 10:06 PM
CrossfireRSSS's Avatar
Default Want to add Fog Lights to Base Roadster
Any suggestions on where to buy, or instructions on how to do it ? Would prefer to used OEM but not sure if they are available ? Is it possible to hook them up to factory switch ?
Thanks,
Dennis
Old Apr 5, 2007 | 02:14 PM
droptopxfire's Avatar
Default Re: Want to add Fog Lights to Base Roadster
Dennis,
I just finished installing OEM fog lights (purchased from dealer) on my Base Roadster. Yes you can connect to the OEM headlamp switch. If you watch Ebay you my be able to pick up a set there. If you do a search on fog lights you should find some info.
Gary.
Old Apr 5, 2007 | 02:50 PM
Romio's Avatar
yea i would say get the OEM ones that fit everything and looks good.
Old Jun 11, 2007 | 05:44 PM
ntenspy's Avatar
Originally Posted by droptopxfire
Dennis,
Gary.
I have been looking for this kit for a while with no luck. droptop how much did you pay for OEM kit? I would be interested in OEM also because I want to use the factory switch as well. When I search Ebay all I get is lamps no kits..
Any suggestions TIA.
Old Jun 13, 2007 | 07:12 PM
mkl's Avatar
mkl
Dennis,
Gary.
Hi Gary,
Can you tell me how difficult it was to have them installed? I have spoken with the Chrysler dealer who does not have a clue. Did you go to a dealer or to a auto electronics shop?
My email is mklpwl@yahoo.com if you want to reply "off forum".
Thanks,
m powell
Old Jun 15, 2007 | 04:48 PM
MKL - I did the install myself.
Ntenspy - No kit is available that I'm aware of that is a direct bolt in.
I purchased the factory lights ($150 for the pair) some 18 gage wire and connectors to match the lights ($15 from your local auto supply store). You use the factory switch. Install a fuse in the #9 slot to make the switch hot for fog lights and with the aid of the wiring diagram you can wire from the switch to the lights. A little soldering and you're all set.
I got my light from the dealer because I get an employee discount but you can get them from www.wholesalemopar.com for about the same price.
Old Jun 15, 2007 | 05:38 PM
#6
droptopxfire
Where did you get the connectors for the junction box ? I also want to use the factory switch/****. I had trouble getting a size that was small enough to fit inside.
Thanks for the info,
Dennis
Old Jun 16, 2007 | 09:21 PM
Dennis,
I pirated them from a scrap wire harness that came along with a switch assy. I purchased from Ebay.
Gary
Old Apr 2, 2009 | 06:07 PM
rdougc's Avatar
Dennis,
Gary.
Gary or Dennis
was there a problem mounting the fog lights, With the blankout removed did they fit OK. It has been a while since you rote this hope you still visit crossfire forum. Fhanks in advance I want to add OEM lights to my 2005 raaster.
rdougc
Old Apr 2, 2009 | 07:07 PM
nox1s's Avatar
Just out of curiosity, why do you want foglights?
I don't think in the 4 years of me owning my car, i've ever used them once ???
Old Apr 2, 2009 | 07:22 PM
bhays's Avatar
I just installed fogs when I put my SRT bumper on. It's much easier to get one of those add a circuit connectors that hold two fuses. Plug it into the #9 spot and connect the hot wire to your fogs, grab a ground under the hood and you're good to go. They even stay on when you shut the door with the parking lights.
Old Apr 2, 2009 | 07:34 PM
rdougc's Avatar
Dont like the blank covers. If they had painted them to match the car it might make a difference
rdougc
Old Apr 5, 2009 | 06:54 PM
No Problem installing the lights, just remove the blanks, I think 3 srcews each. The OEM fog lites mount to the same location.
nox1s-if you don't use the fog lites maybe you could remove them and use the opening for a cold air intake.
has anyone tried this???..Just a thought.
2004_
Jul 9, 2025 12:39 AM
wootto
U.K.
Aug 16, 2020 07:55 PM
jgreen
106
Sep 18, 2017 11:46 PM
stlas69
Sep 3, 2015 10:28 AM
bradleykologek
Jul 6, 2015 02:49 PM
