dashboard light bulb replacement
Old Apr 20, 2007 | 11:52 AM
alipsa's Avatar
Default dashboard light bulb replacement
One of my dashboard lights is out (the light that comes on when the headlights are turned on; not the warning lights on the dashboard). The local Chrysler dealership quoted $204 to replace one bulb, telling me that the entire dashboard needs to be removed. Surely, the engineers must have anticipated that bulbs would need to be replaced and had the foresight to provide for some simple procedure. Is the dealership correct, and if not, does anyone know how to inexpensively replace a bulb?
Old Apr 20, 2007 | 12:21 PM
GatorLCA's Avatar
Default Re: dashboard light bulb replacement
I heard that if you pull the steering wheel out as far as it can go you have access to the panel. Search for dash bulb and it might come up but someone here has done it.
Old Apr 20, 2007 | 01:03 PM
msheredy's Avatar
I ran across this site. It sounds like the dealership was close.
http://www.mercedesshop.com/Wikka/R170InstClusterBulbs
Old Apr 20, 2007 | 04:07 PM
AMGLover's Avatar
Deleted Message
Old Apr 20, 2007 | 07:09 PM
MMZ_TimeLord's Avatar
AMGLover is correct. This is a VERY good precaution. It is even more vital when repairing or other wise exposing wiring that has airbag detonation trigger wires running through it.
Be safe, disconnect the battery.
Old Apr 20, 2007 | 08:20 PM
Shouldn't this be covered by your warranty?
Old Apr 23, 2007 | 11:15 AM
alipsa's Avatar
Unfortunately the warranty expired 11/06. I don't want to do the repair myself & screw up the airbag. I think I'll just live with a dimmer dash- $200+ to replace a dashboard light is a bit steep.
Old Apr 23, 2007 | 11:18 AM
alipsa's Avatar
I tried your suggestion, but extending the steering wheel didn't provide me with any access. Thanks for the suggestion though.
Old Apr 23, 2007 | 11:25 AM
alipsa's Avatar
The website appears to give pretty good step by step instructions. I wouldn't mind trying the bulb replacement myself, but because of AMGLover and MMZ_Timelord's warnings about the airbags I am hesitant to trying to do it myself.
Old Apr 23, 2007 | 08:27 PM
alipsa,
A simple disconnect of the negative battery terminal is MORE than enough to prevent discharge of the airbags.
It's also the main precaution when doing any wiring work.
When you are changing a dash illumination bulb, you will be unplugging things, so it's better to have all power disconnected.
By disconnecting the ground wire from the battery, you are leaving no return path to the battery to complete a circuit. Even if a hot wire fell across a bare metal surface (not likely in a new car) it would not be able to complete the circuit.
The warning was not meant to make you afraid... it was meant to inform you.
2004_
Jul 9, 2025 12:39 AM
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
KwehCat
Jul 16, 2015 04:48 PM
joethejeweler
Jul 7, 2015 08:58 PM
