Firewall Grommet?
Old Jul 11, 2007 | 08:51 PM
nox1s's Avatar
Default Firewall Grommet?
So, I need to run a line from my battery to the inside of my cabin. I did a search but not much really came up.
Does anyone know of any easy way (without drilling preferably) to get a wire inside the cabin from a grommet or something of that nature?
Thank you in advance,
Troy.
(Edit: To clarify, if I can do it without removing the battery that'd be preferred).
Old Jul 12, 2007 | 12:03 PM
spensley's Avatar
Default Re: Firewall Grommet?
If you search on your message title...
https://www.crossfireforum.org/forum...rewall+grommet
Old Jul 12, 2007 | 02:26 PM
droptopxfire's Avatar
Run the wire(s) to the Power Distribution box next to the Brake master cylinder, there is a rubber bung, poke a hole in it and run the wire thru that and then it's inside the cabin.
Remove the lid on the PD Box and shine a flash light in there then go look inside the car under the dash and you'll see were the wires come in.
Also If you check my Gallery I have a couple of photos showing the wires going into the PD Box.
Hope this helps.
Old Jul 12, 2007 | 07:34 PM
HDDP's Avatar
Troy.
Depends on which side you need to enter... be more specific... Battery is on the passenger side on US cars, driver side on UK cars... I didn't look to see where you're from...
EDIT:
I noticed MI, so there is a huge oval access port just aft of the battery, another couple of 2" holes for the heater hoses... never mind, I'll post a picture when I get a chance...
maxcichon
Oct 27, 2016 11:08 AM
shawnwatson9493
Jul 9, 2015 11:47 PM
jiggityjosh
Sep 26, 2012 10:07 PM
astrnmrtom
Oct 20, 2010 07:58 AM
green-ghost
Mar 9, 2010 09:07 PM
