New Grill Design Forum
Originally Posted by XFiringInNC
Yeah, that one's ugly, but there was one that someone found that didn't have that. Unfortunately, it is a one off that some company made for their own show car. I called them and they weren't interested in reproducing (it was a company that did other performance parts, not grilles).
It looked like this:
aparently so.... This gives us a few more options. I know where there is an SLK that I can go check out and take some measurements tomorrow.
I couldn't find anything at mbworld either.
Originally Posted by DrMike
Anyone know where to get this one, love the Bentley look
Originally Posted by RPM
Any measurements?
Where did you find this grille to order?
I couldn't find the one I was going to measure but I did follow a SLK32 AMG to Target last night. After the owner went into the store, I sneeked up and took some measurements. Now I am really confused. The SLK with the Crossfire grille appears to be using the whole gille. Our grille is seven inches from the bottom opening to the bottom of the Chrysler badge. The SLK openng was 5 inches on the car I measured. Maybe there are different size openings on the SLK?
That was a one off creation. The company has no interest in producing them and does not know what happened to the one in the pic.
Originally Posted by MAYAman
The frame on that one is to thin, it looks rice. and you can easily see all the components behind it. It has to be middle ground. When you look at the mesh on other performance cars you can't see the radiator and all that other crap. And the mesh is more substantial. A little thicker border and set it more at an angle that matches the factory grill. That one is to vertical
Also look at the gap between the grill and the wings? Its like 3 inches. If they could produce that with the mesh following the contour and placement of the factory grill then you'd have something.
The gap between the wing logo and mesh is especially nice since it makes the wing look like it is "floating." Perhaps mounting a low voltage backlight behind the wing would futher enhance the floating effect and floodlight the shinning mesh at night and give a little Motorama drama to our production concept cars.
I also have no problem with seeing the radiator through the mesh as it makes the design more "authentic." The original mesh covers used in the 1920s and 30's were simply stone guards to protect the vulnerable radiator fins or the expensive vanes of the radiator cover.
I think this grille would look even more attractive on the more art deco-inspired coupe body.
Fortunately, beauty is in the eye of the beholder
Chris
is there a way we could get somebody to make grilles like that one-off for us? i just really like the way that one looks over all the others I've seen. I'm probably going to go to JRs Custom Auto here in Dallas after school tomorrow (its like 2 minutes away) with a picture and see how much they would charge to make tha (assuming they will). I'll let you guys know anything I find out
hey TeXfire71,
do you mind asking if they can also fabricate the rear hatch? the same one from the picture. im from Singapore and there are no custom fabricator is this country at all...
cheers
Eddy
cheers
Eddy
yeah unfortunately I ran out of time today to go. I ended up having to set up for some dinner that's going to be at the school. I'll call JR's in a little bit, and yeah sure no problem I can ask about it for you. Although just a warning. JR's isn't cheap. At all. They are really high quality and stand by their work for life, but they charge a LOT more ususally... just sayin
Originally Posted by apkano
I like that design...it's the closest I've found to the Bentley grill.
http://www.bentleymotors.com/Corpora...spx?infid=1107
Those look the best in my eyes.
Bentley painted.
