Rear License Plate Holder
Old Dec 26, 2007 | 09:16 AM
Utah12's Avatar
Default Rear License Plate Holder
I will be installing my license plates this week. I plan on only putting on the rear for now. I have the plastic temporary holder that the dealer installed. Any recommendations on what I should buy to replace it? What prevents the plate from scatching the car? I have had this problem in the past.
Old Dec 26, 2007 | 10:34 AM
phyrephlyte's Avatar
Default Re: Rear License Plate Holder
What ever you use, I always stick those thick rubber furniture pads on the back of each corner. Inward enough not to be seen on the edge. When you tighten the screws you get a nice secure fit and no tag rattle. I've done this for years and never had one come off no matter how hot or how hard I rinse the tag.
rp
Old Dec 26, 2007 | 11:07 AM
Utah12's Avatar
A great idea! Thank you! I don't know if it really matters on the holder as long as the darn dealer's name is off of it. I hate that! I'm going to look for one in powder black with nothing written on it.
Old Dec 26, 2007 | 02:16 PM
Utah12's Avatar
OK I took off the dealer mounted license plate with associated cardboard dealer advertisement and I was horrified. Four bulging (extruding out of the surface of the car body) holes made by self tapping screws and bad nicks at each of the corners where the holder was tightened to excess. I know the holes will be covered but these nicks at the corners will now start rusting. I can't imagine a dealer doing this to an expensive car or any car for that matter. Am I overreacting?
Old Dec 26, 2007 | 02:20 PM
It's plastic and therefore won't rust.
Old Dec 26, 2007 | 02:28 PM
Utah12's Avatar
The material the plate is fastened to is metal!
Old Dec 26, 2007 | 02:33 PM
Utah12's Avatar
To clarify the plate holder was screwed in so tightly that it caused nicks at all four corners in the car body.
Old Dec 26, 2007 | 03:05 PM
That part of my car is a composite. Everything below the hatch door that you can see is not metal.
So do a good touch-up and don't worry. Also buy one of the wider tag frames. Those pads I told you about will not let this happen again.
Nobody takes care of your car like you do.
RP
Old Dec 26, 2007 | 03:09 PM
CrossfireLTD's Avatar
Cool Re: Rear License Plate Holder
You can also use the soft part of a self adhesive velcro strip.
Old Dec 26, 2007 | 03:13 PM
Utah12's Avatar
Thank you! I just have never seen someone putting large sheet metal screws into a plastic part. I will get some touch up paint and hit the four corners. The rubber will prevent this from happening again.
That's what I used to keep the hatch stops from taking the paint off from around the inner hatch opening. It also seemed to take care of that creaking sound that came from the rear driver's side area.
RP
Old Dec 26, 2007 | 03:22 PM
Utah12's Avatar
What did everyone do about the 3/4 inch hole behind the license plate? I would like to put a rubber plug there if I could find one the right size. I would think water would find a way in if it was left open.
Old Dec 26, 2007 | 03:32 PM
It's my understanding that the rear license plates are installed by the dealers. Someone else here was complaining that his was installed crooked. Mine was only screwed in with two screws at the top. So, I don't know what 3/4" hole you are talking about. It must have been done by the dealer. Maybe someone else here has an idea for a patch.
Old Dec 26, 2007 | 05:12 PM
Utah12's Avatar
There is a 3/4 inch diameter hole which appears to be an access port to a alan screw. This is directly behind where my license plate goes. I'd like to hear what other owners have done with this.
Old May 13, 2008 | 11:42 AM
rock's Avatar
RP
What is what you used used to keep the hatch stops from taking the paint off from around the inner hatch opening? I am presently having this problem.
Old May 14, 2008 | 12:55 PM
ppro's Avatar
I went with a very basic thin-line chrome border that goes on the plate and a clear cover over it. I found some funky knock-off screw covers that reminded me of my E-Type so I put them on for fun.
Click for more
Old May 14, 2008 | 01:35 PM
Originally Posted by ppro
What is that decal for next to your plate?
Old May 14, 2008 | 02:07 PM
ppro's Avatar
That's related to a GPS activity on geocaching.com using billion dollar defense satellite technology to find tupperware in the woods...
If you are involved with Geocaching and happen to find my car, you can enter the number on the sticker to "discover" it like any other travel bug (registered items that have movement tracked on the website)
Here's the page for the car (click)
Old May 14, 2008 | 05:42 PM
+fireamx's Avatar
I use a 1/2" thick piece of styrofoam that's cut a little smaller than the size of the license plate. I used double sided tape to stick it on the back of the plate.
The styrofoam doesn't hold water when you wash your car, and it gives the license plate a nice cushion to tighten the plate against. Plus it gives the license plate a safe "buffer" zone to keep the plate from making contact with the painted service.
deerhunter
Jan 16, 2021 10:56 AM
pioneer4x4
Apr 17, 2016 10:26 AM
pcrs29
Aug 29, 2015 12:21 PM
55chevy
Aug 15, 2015 09:57 PM
autumnmass
Jul 30, 2015 01:06 PM
