Got My Hid's But...
so i got my hid's in the mail today put them in, took a while to get the spring clip back in, my bad anyways i got them both in and one side seems to have more of a blue tint to it i got the 5000k kit is there anyway to see if maybe there was a different temp buld mixed up in there? my first set of hid's is it something i did?
Originally Posted by v8valiant
also do they all do the flicker when you first turn them on? thanks guys!
I have 5000k bulbs and they are definitely blue. Are bulbs situated correctly? If not that may be the culprit.
Also they do flicker for a second when powering up - the ballast is putting out some high voltage to ignite the bulb, then it goes down to normal operating voltage.
I installed (replaced 5000K) with 4300K and I'm much happier.
I'm spending the next 1-2 hours writing up a nice how-to for this.
I'll title it "HID Install with Photos". It will be in the "Exterior and Lighting" forum.
Mine were in the mail yesterday as well.
Appeared more blue than I expected but seems to make a nice difference on the road.
Biggest difference is the width the light reaches. I notice signs that are set far from the road reflecting much more.
I could not find a place I liked for the ballasts so I ended up removing the headlights and using the self under them. This worked out pretty well as the ballasts are just about invisible.
Install posted.
xfireohio
Jul 20, 2020 12:03 AM
Adrian_X
Nov 9, 2017 08:49 AM
