Wiper grommets the same?
Old Sep 26, 2009 | 02:38 PM
LugNut's Avatar
Default Wiper grommets the same?
One of the wiper pivot-to-cowl cover grommets (aka "insulator" in MB-speak) was missing on my XF, so I just installed one. However it is too big (hole in the black plastic cowl cover is too small, as well as off-center). Could someone please look at your XF's and tell me:
1) Are both grommets installed on yours? Mine was missing on the driver's (US=left) side.
2) If you have a driver's side grommet, is it the same size as the other?
Here's a dark pic of the locations:
Thanks!
Old Sep 26, 2009 | 02:47 PM
Default Re: Wiper grommets the same?
Both of mine are missing, not worried about it really.
But I did just help another member install a new siren. I didn't see any difference in the right and left caps when I removed them. Going back on, I put a nice glob of black silicone on each one to keep them from coming off in the future.
James
Old Sep 26, 2009 | 02:52 PM
LugNut's Avatar
Mine was also missing one wiper-nut cap -- the MB replacement was $$, but fit great. But are your (and others?) rubber pivot-to-cowl grommets missing (too)?
Old Sep 26, 2009 | 02:59 PM
OK, I went out and took a look with a flashlight. Here is what I found:
LEFT
RIGHT
Old Sep 26, 2009 | 03:23 PM
I wonder if this is something you can find the hardware store i.e. Home Depot?
Old Sep 26, 2009 | 03:35 PM
My driver side grommet is missing as well, as the wiper pivot is off center to the hole I think they left them off.
I had to purchase a nut cover as well, it was $7. but worth it.
Old Sep 26, 2009 | 04:14 PM
LugNut's Avatar
OK -- thanks! Sounding like a last-second installation problem at the factory -- they didn't mold the hole in the cowl cover correctly.
I just put the new grommet under the wiper arm (and on top of the cowl cover), and reinstalled the wiper arm. _If_ I drove the XF in the rain, a lot, the new grommet would fall apart over time. Not likely to happen ...
Old Sep 26, 2009 | 05:09 PM
32krazy!'s Avatar
i think it goes back father than your model yr! i looked at my 2002 slk32 and the driver side has no grommet or nut cap. pass side has both
Old Sep 26, 2009 | 06:17 PM
maxcichon's Avatar
Now, that's funny.
I have no grommets, and it came with no caps-I bought those 2 years ago.
I'll find a suitable replacment for the grommets and let you know. Another mission!
Old Sep 26, 2009 | 06:29 PM
LugNut's Avatar
Here's the parts that work, except for the left/driver's side grommet:
Wiper pivot-to-cowl grommet/seal/isolator, black (*** center/right pivot only ***)
MB 1708240098
DC 5101283AA
Wiper arm-to-pivot nut cap, black
MB 0008240249
DC 5101489AA
Good prices (MB-versions: $1.50 and $2.93) from Mike at OE Discount Parts
Old Sep 26, 2009 | 06:39 PM
maxcichon's Avatar
MB 1708240098
DC 5101283AA
MB 0008240249
DC 5101489AA
Thanks! This is why I keep coming back-customer service!
Old Sep 26, 2009 | 10:42 PM
Thanks!
Now we can see what you are talking about , I just used Picassa on it.
In the dark all Crossfire cowls look grey.
Old Sep 27, 2009 | 09:07 AM
green-ghost's Avatar
my center nut cover (easy guys ) was missing, $7 to replace, then noticed my d/s grommit was missing too. Ive tried to pull the wiper off but all I could seem to manage to do was get the nut off (easy guys) and it seems like theres no way to remove the wiper arm...any help?
Old Sep 27, 2009 | 09:20 AM
Loosen the nut until almost off. Spray some penetrating oil (PB Blaster, etc...) down around the splines. I had to use a battery terminal puller to get both of them off. I found them to be corroded (different metals) and caused them to be locked on and they were harder to get off than I expected. Both sides had caps on them so they didn't help at all.
Keep the nut on the shaft so you don't mushroom the threads on the shaft when using the terminal puller.
James
Old Sep 27, 2009 | 10:47 AM
Iamfink2's Avatar
I couldn't remove my wipers as well so I went to Advanced Auto to buy a battery terminal remover as James stated when I got there they sold a wiper puller so I bought that and it works perfectly. I think it was about $10. I use it all the time to remove the wiper arms when I treat the wiper cowl to restore the color. Pat
Old Sep 27, 2009 | 04:56 PM
newCrossfire's Avatar
wow i thought the techs at chrysler kept ripping me off, i just replaced the drivers side cap and its already missing! good to know this is a common problem before i gave the service manager crap for this missing cap.
Old Apr 19, 2013 | 06:47 PM
bluecoupe's Avatar
Thanks!
Isolator requires 1.5 inch dia. opening, driver side is smaller and off center, however it can be modified with an exacto knife to allow the isolator to fit.
Old Apr 19, 2013 | 07:01 PM
Old post, LugNut hasn't posted for18 months. LOL
But I appreciate it as I have two isolators on order.I will be fitting one soon I guess. I have a spare.
Part number, Chrysler #5101283AA
My dealer never bothers to call me when they are in, I have ordered parts and they have returned them to the warehouse, makes you wonder why they are in trouble.
Old Apr 19, 2013 | 07:25 PM
bluecoupe's Avatar
Dave, my post was for your benefit. I saw that you had ordered the isolators, however I couldn't find your post, so I figured you would see this.............
Old Apr 19, 2013 | 07:46 PM
Thanks, somebody cares.
Search is my friend.
