headlight spring clips
Old Oct 22, 2009 | 09:24 PM
inot2old's Avatar
Default headlight spring clips
Does anyone have an extra headlight spring clip lying areound that they could sell me? I lost one while replacing a bulb. When I went to the dealer about getting one, they said I would have to buy the whole headlight assembly .
Old Oct 23, 2009 | 05:58 PM
maxcichon's Avatar
Default Re: headlight spring clips
My suggestion to you:
if you strike out here-take one out of the another position and head to a local machine shop. I'm sure they can make them, but it may cost $20 or a bit more.
Better than nothing...
Old Oct 23, 2009 | 06:13 PM
waldig's Avatar
Talking Re: headlight spring clips
Describe it and or get me a photo and your address. Have a set of lights that I was cutting into to do some special projects with. I have a spare, need clear description so we get it right.
With data and address Ill mail it Monday
Weekend W DY
Old Oct 23, 2009 | 08:36 PM
Larry Hitze's Avatar
inot2old, I have one also if needed. Just let met know but it sounds like it is handled.
Old Oct 24, 2009 | 06:43 PM
inot2old's Avatar
Thanks, guys. Waldig, I sent you a PM.
Old Oct 29, 2009 | 05:54 PM
inot2old's Avatar
I got the spring clip from Woody & was able to get it put in with the help of a mirror. I should have read the instructions for changing the bulb on this site first, it would have saved me a lot of trouble. I also realized ( thanks to this site) that I hadn't put the drivers side bulb in right last year when I replaced it ( I didn't get it seated right), so I was able to correct that. I finally have headlights that work right. Thank goodness for CrossfireForum.org.
Old Oct 29, 2009 | 08:31 PM
nox1s's Avatar
Did you put in HID lights? You should! They're marvelous..!!
Old Oct 29, 2009 | 10:02 PM
beasticles's Avatar
I need one too. I can't believe you can't pick up that piece from the chrysler dealer. its annoying as ****.
Old Feb 6, 2012 | 06:09 PM
Sophi27's Avatar
I know it's been forever but do u happen to still have those clips? Or know where I can get one? Thanks!,,
Old Feb 6, 2012 | 06:53 PM
PM maxcichon - if he's in a good mood, he'll send you one ......
Old Feb 6, 2012 | 07:06 PM
Alaxfire's advice is good, I sent my last spare to Maxcichon to use as a pattern to make new one's. I don't have any extra's now - sorry.
Old Feb 7, 2012 | 08:18 AM
maxcichon's Avatar
Red face Re: headlight spring clips
Larry, I'm sorry 'bout that! PM me your address and I'll send one to you!
Old Feb 7, 2012 | 01:30 PM
Its not a problem, I have not needed one yet.
Old Dec 21, 2012 | 03:29 PM
terry b's Avatar
bought a 2005 roadster. Changed a low beam bulb - clip was missing. I can sympathize as I fought these for years on a volvo.
Anyone know where I can get one? Of course I would pay. Its ridiculous that you have to buy a whole head light assembly.
Anyone know if SLK's used these? Maybe mercedes sells them.
I'll probably scour a few junk yards.
Cheers and merry christmas
Terry
Old Apr 21, 2013 | 12:32 PM
driver313's Avatar
I have a few of these and they are $5 the problem is shipping is $5 for one or as many as you need.
Old Aug 1, 2013 | 12:54 PM
Spuds's Avatar
Just a suggestion for all of you that are looking for those clips. I have been driving my 2005 Roadster for 3 years with a "dim" and strangely angled drivers side low beam. High beam looked great so I didn't want to try to adjust the low beam since the vertical adjustment applies to both. Finally, after reading the posts on headlight replacement, I got to thinking maybe it is not seated properly so I pulled off the cap to check. Guess what? No clip. Bulb was just laying in there loose. NO WONDER IT IS NOT AIMING CORRECTLY. Removed the clip from the High Beam to use as a guide and I made a new one using a paper clip. First try didn't work so good. Used a smallish clip and it wasn't strong enough. On the second try, I used the largest paper clip that will fit in the holes on the assembly. After a few adjustments, I got it to work and the headlight is perfect. All it cost me was some disinfectant and some band aids. Who designed these things anyway. Thank God it was on the passenger side. By the way, have a mirror handy. You really can't do it without one.
Old Aug 1, 2013 | 07:44 PM
srbaker's Avatar
Just bought my car a month ago, passenger side low beam went out. Found black tape and goop holding bulb in. Obviously the previous owner or dealer lost the clip.
I went to Chrysler and ordered the rubber cup that was missing but need clip. Do you still have any?
Thank-you
smfrycruzr
Jul 17, 2023 05:33 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ayebb
Sep 18, 2015 03:35 PM
RiderJC
Sep 7, 2015 11:19 PM
jaesa
Sep 7, 2015 01:50 PM
