headlamp assembly
Old Feb 7, 2011 | 02:48 PM
bboombotz's Avatar
Question Re: headlamp assembly
First I am sorry to post to an old subject. I am new, finally got my registration working, and wanted to get some advice. My headlamp assembly is broken, both have cracks and now one of the units has faulty wiring. So, I am looking to get them both replaced. Could anyone recommend a parts store, 3rd party wise, for the assembly?
Thank you so much!
Rob
Old May 16, 2011 | 10:27 AM
skmaas's Avatar
Default Re: headlamp assembly
Take there advice first, buying the headlamps new & replacing them is a extreme cost. New
l/h & R/h on ebay new, is 900.00 plus shipping dealer you can add another
30%
Old Jul 11, 2011 | 03:01 PM
Breezing's Avatar
Nice job!
But I have never seen them haze on the bottom of the lens.
Was your car left upside-down for a long time?
Just kiddin'!
My 2005 headlight covers are really bad on the bottom of the lens as well. I buffed with 3M product which appears to have done an OK job but it looks like they are equally bad on the INSIDE. I can't find any info or discussion on this. Anyone? Tried to remove the entire headlight and couldn't, finally found instructions, but before I try I wanted to find out if I can remove the cover to clean the inside or is it all one sealed unit? Seems like a great deal of work to remove.
Old Jul 11, 2011 | 03:47 PM
skmaas's Avatar
The headlamp is all 1 unit, you will not gain access to inside for cleaning. as for removing and replacing after lots of trial & error its not as difficult as it seems, anyway you look at let a pro do it, i still had to have them professionally aligned & the mechanic stated he would have done the install with alignment for no additional charge.
Old Jul 11, 2011 | 04:39 PM
Breezing's Avatar
Dang, that's what I thought. Thank you much! Saved me a great deal of time.
Old Jul 12, 2011 | 08:58 AM
gtennant's Avatar
All this commentary on how-to/what-to do to remedy the plastic lens deterioration is great. I have used one of the multi-wet-sand-and-polish solutions with no better than acceptable results (not, say GREAT). My thought from the jump has been: why in the hell did Chrysler/MB not go for shatterproof glass? I have an '02 MB C240 whose glass lenses are as flawless as the day the car left the factory. I hate the idea of having to spend what we are needing to, in order to rectify what I regard as a terminal design defect. All that said, it's really academic why this was not the chosen course. Is anybody making aftermarket glass replacement lens/housings? Short of that, are there any worthwhile suggestions for the preservation of a restored (de-fogged) lens/housing (I've read the use wax, vaseline, spray clearcoat, etc., and don't see a definitive solution among them)?
Many thanks,
George
4drturbo
21
Nov 12, 2018 04:50 PM
4drturbo
Oct 2, 2015 12:58 PM
stlas69
Sep 14, 2015 06:45 PM
jaesa
Sep 7, 2015 01:50 PM
Boresite
Aug 9, 2015 10:33 AM
