How does grill come out of the roadster??
Old Mar 1, 2010 | 03:05 PM
popeye's Avatar
Exclamation How does grill come out of the roadster??
Have some duplicolor steel wheel paint that matches the wheels and the windshield surround and want to paint the dark parts of the grill the same color. I need some pictures or explanation on how that grill comes out so I can tape it and prepare it. I see 4 10mm bolts right on top of the grill easy to get to..,where else does it fasten to the roadster?
Thanks Popeye
Old Mar 1, 2010 | 03:07 PM
apkano's Avatar
Life is random...so am I.
Default Re: How does grill come out of the roadster??
Aside from the bolts on the top there's just a couple of clips on the bottom of the grill. If you look closely you can probably find them and pop them out with a screwdriver.
There's 4 clips I believe.
Old Mar 1, 2010 | 03:10 PM
with those bolts out (on top) put both hands inside the grille as low as you gan get and pull twards you there are 5 i think clips that will pop loose when you pull it ,,,when reinstall be sure those clips snap in (or at 70 mph it will blow off the car and you can't fing a new one. jim
waldig
Sep 2, 2015 11:02 AM
dizzy
Aug 18, 2015 03:57 AM
itsky
Aug 4, 2015 10:35 PM
KDW4Him
Jul 31, 2015 10:21 AM
waldig
Jul 29, 2015 06:54 AM
