Headlight lens crazing & clouding 2006 Roadster
Old May 1, 2010 | 12:32 PM
tn06's Avatar
Question Headlight lens crazing & clouding 2006 Roadster
Bought a 2006 Roadster with low mileage. Only has 12,000 miles now.
Since it was not put into service until 2008, still under warranty
The headlight lenses are crazing and clouding at the top.
I took it to the dealer and he says he cannot do anything about it.
I think under warranty he should just replace it and be done with it.
I've read a lot of similar complaints.
Has anyone out there had the same issue and successfully resolved it?
Old May 1, 2010 | 12:40 PM
Default Re: Headlight lens crazing & clouding 2006 Roadster
I do believe many have had theirs replaced under the original factory warranty....
Old May 1, 2010 | 01:33 PM
Erzer's Avatar
Had mold starting in the high beams...replace whole assembly. When you go this route, ask them to give you the retaining clips and caps as you can't buy just those parts and they could come in handy.
Old May 2, 2010 | 11:04 AM
maxcichon's Avatar
I agree.
BTW, those might be the worst I've seen. Wow.
Old May 2, 2010 | 02:17 PM
Do not take any BS tell them to replace them. If they give you trouble ask to see the Chrysler rep, no satisfaction from him go higher.
Politely tell your dealership that unless its fixed you will not be coming back. You did them a favor by taking the car out of their hands so its payback time.
With lights like that it's only worth half the normal price, so if you cannot get it fixed I'll buy it from you sight unseen.
Old May 2, 2010 | 05:07 PM
Infinite's Avatar
Thats not that bad as far as headlights go, you could wetsand them and fix the issue yourself and bypass the stealership
also, the reason headlights do this, is they arent maintained... a good coat of cleaner wax 1-2 times a month keeps headlights uv damage free
Old May 2, 2010 | 06:04 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
lol. Nice offer... but I'll sweeten it to 55 percent of what you paid. j/k
Make those bastards replace them under warranty. Good luck.
Old May 3, 2010 | 06:09 AM
Melspank's Avatar
I also had the same problem on my srt, It was still under warranty and both headlights were replaced at a cost to the dealership of around 760.00 a piece. If you stand your ground you should have the same result.
Melspank
SRT-6
Old May 3, 2010 | 07:24 AM
///SilverSaphRT6's Avatar
Are those spider cracks? Dont know if you wanna wet sand that.....may have to take to much sanding to get that out.LOL Try another dealership.
Old May 3, 2010 | 07:35 AM
maxcichon's Avatar
I have to agree.
Old May 3, 2010 | 10:00 AM
former NXMX5's Avatar
wouldnt the warranty be over... 3 years?
Its an '06 right?
Old May 3, 2010 | 12:05 PM
maxcichon's Avatar
Its an '06 right?
"Bought a 2006 Roadster with low mileage. Only has 12,000 miles now.
Since it was not put into service until 2008, still under warranty."
Old May 3, 2010 | 01:27 PM
kingkub57's Avatar
Isn't there a TSB or something that the dealer has about hazzing or delaminating of the head lamps ? ( I'm sure theres someting in the forum about this ) I know thats how I got mine replaced for delamination, everyone here is correct you should try another dealer, or start the ladder Service manager, General manager, Owner, Factory warranty rep etc. the dealer really should be replacing them with no hassles.
Old May 3, 2010 | 03:19 PM
oops! good catch.
Old May 12, 2010 | 02:02 PM
liberty1's Avatar
I had my my drivers side replaced under warranty almost two years ago. The passenger side is being replaced tomorrow under warranty as well. Part arrived in a day. Ordered some touch up paint who knows when I will see that
Old May 12, 2010 | 03:42 PM
patpur's Avatar
Senior Member/Moderator
Those are pretty bad, as bad as I've seen. Even if the dealer replaces them they still tend to etch and haze over time. Infinite is right, you have to maintain them once you get them right. You can try the Meguiars kit, those definitely need the sanding treatment. Once you get them right you'll still need to wax them often. Even then you will get haze and etching. Mine get waxed monthly and shot with detail spray every week after I wash the car. They still etch after a few months and I pull out the buffer and the Plastx. 5 minutes with an Lake County Orange cutting pad, the PC and the Plastx and they are good as new. Probably do it this weekend as a matter of fact.
Old May 12, 2010 | 05:28 PM
tn06's Avatar
The car is a 06, but was not titled until 08, so warranty goes to June 2011
Old May 12, 2010 | 05:51 PM
KrzyFast's Avatar
When you do get them sorted out (Replaced or fixed), you may want to think about having 3M film installed on them. It protects them from road grit and bugs so they do not get that sparkle look to them. DIY kits are like $50 for both and they are cut to fit. All you need is some soapy water and a plastic squigy. I had mine done 2 years ago. It is great stuff!
Good luck!
Cheers,
KrzyFast
Old Oct 8, 2010 | 09:08 PM
tn06's Avatar
After going to the third dealership I found a new one that was glad to replace my crazed lens. The lens were on back order and it took about 5 weeks to get them, but it was worth it. If in Nashville go to Gary Matthews Chrysler Jeep, they were very helpful.
csteve0355
Jul 28, 2015 11:12 PM
maxcichon
Jul 21, 2015 09:46 PM
Mark McKay
Jul 17, 2015 01:18 PM
jwcrossfire
Jul 15, 2015 04:36 PM
GWAPA
Jul 8, 2015 07:25 PM
