eyebrow lights again?
Old Mar 21, 2011 | 11:11 AM
Sheldon's Avatar
Default Re: eyebrow lights again?
Got the LED fog bulbs in this weekend.
Now have lights out indicator when the fogs are turned on
Old Mar 22, 2011 | 06:56 AM
green-ghost's Avatar
did you get can bus leds
Old Mar 22, 2011 | 11:41 AM
Sheldon's Avatar
Nope looks like I clicked on the wrong one now that I look at it. Oh well, someday I will change them out
Old Apr 6, 2011 | 03:35 PM
604Cash's Avatar
Green-ghost, could u post pics of the LED lights installed in the eyebrow location? This seems like an easy cheap mod that makes a big difference.
EDIT: or anyone else that has done this mod, be great to see some outcome pics.
Old Apr 6, 2011 | 05:52 PM
Sheldon's Avatar
It's slightly overcast out, you can see how dim the lights are during the day...
Maybe it's just the ones I got
Old Apr 6, 2011 | 06:18 PM
604Cash's Avatar
Sheldon, which LED's are those? 3-LED? 5-LED? Some dusk and night time shots would be awesome!
Old Apr 6, 2011 | 07:39 PM
Sheldon's Avatar
They are 8 LED, 4 on the front facing out, then 2 on each side of stick thing... I know that makes no sense, I will find the place I ordered them from.
EDIT: Here are the ones I have
Here is a pick at 5:40pm (sorry one of them is blurry as hell)
PS, I hate my yellow side markers, can't wait to have those painted over
Old Apr 6, 2011 | 07:53 PM
604Cash's Avatar
Wow, nice! Thanks for the pics. I'm gonna be ordering a bunch of LED's for the whole car real quick here.
Old Apr 6, 2011 | 10:32 PM
604Cash's Avatar
Originally Posted by Erichenderson02
Rear panel black out... niiiice.
Keep us up to date on this mod green-ghost!
Old Apr 10, 2011 | 06:03 PM
I got the 3 leds for eyebrows(one front, one top/one bottom, but if I was to do it again Id get the ones that have 4 leds facing front as the one (of the 3) that faces front isnt to visable in the day time. I like to use the eyebrows for driving lights
Old Apr 11, 2011 | 02:36 AM
604Cash's Avatar
2 Car Bulbs CAN-BUS T10 8-LED SMD White Turn/Tail Light | eBay
I ordered these 8LED style lights, from Factorykiss. When they arrive (along with all the other LED's) I will report back to this thread, and probably start a new thread.
Old Apr 11, 2011 | 05:17 AM
THATS A GOOD PIC cASH, I missed that one somehow. Let us know if it works well and I'll get them too
Old Apr 14, 2011 | 01:40 AM
604Cash's Avatar
I'm hoping they'll arrive sometime before the end of the month. Their shipping times seem pretty vague...
Old Apr 26, 2011 | 11:02 PM
srt666's Avatar
Okay I've read every post in this thread and all very informative but so many different opinions. What are the sizes for the eyebrow lights fog lights, and maybe headlights? And what company should I go through to get the best lights without spending 25 a pair?
Old May 2, 2011 | 04:25 PM
604Cash's Avatar
Having major issues getting out pass side eyebrow light. ive got it a quarter turn and it will not budge past that point. Anyone that can help me out with directions or a trick or something thatd be really great
Old May 2, 2011 | 05:30 PM
Erichenderson02's Avatar
The best tool i've found for this job is a pair of 45 degree angled needle-nose pliers. Just reach under with them and grip the bulb base, then use a motion similar to turning a door handle to loosen the socket. (Counterclockwise, just to be extra clear). Once you turn it about 90 degrees it should be free and you just pull it straight back from that point. PM me if you have any more questions.
-Eric Henderson
Old May 2, 2011 | 05:43 PM
Hindin's Avatar
A pair of 45 degree needle nose pliers might help. As I recall the light socket only turns a quarter turn before it comes out. That is from the 12 o'clock position to the 3 o'clock position. Another thing I found helpful was to use a flat blade screwdriver on the nubs on the socket while simultaneously pressing the socket forward (toward the front bumper). Use the screwdriver to pry the socket around. Pushing the socket forward helps take some of the pressure of the socket while trying to release it. In addition before you reinstall the socket take the rubber "O" ring off and put some silicone (or other rubber lubricant) on it. It will make it easier to reinstall and remove if you need to in the future. Hope this helps, they can be stubborn the first time.
Old May 3, 2011 | 03:01 PM
  #38 (permalink)
604Cash's Avatar
Hey guys, thanks for the help. I finally (finally!) got the pass side out and reinstalled with an 8 LED light. Looks great! Also installed my HID kit last night which makes a huge difference in the appearance of the front end.
Old May 3, 2011 | 04:58 PM
  #39 (permalink)
Very nice & Congratulations!
What color temperature HIDs did you go with? And 35 or 55 watt?
-Eric
Old May 3, 2011 | 05:14 PM
  #40 (permalink)
604Cash's Avatar
I went with HIDGATE from eBay on Maxichon's recommendation. It is a 35w kit, 6000k heat. I'd say light output is on par with stock but lights up reflective signs much better than the halogen. Obviously the look is about 700x better than stock.
