How to get INTO the fog light
Old Aug 11, 2012 | 07:28 PM
nickwe21's Avatar
Default How to get INTO the fog light
Hey guys!
I just noticed my left fog light does not work. So I took a closer look at it and it seems the bulb "busted" and there's now glas in the fog light container. How do I get in there to pull all the glas out and how do I replace that bulb? Is it the same bulb as the headlight?
Thanks for the info!
Nick
Old Oct 14, 2012 | 04:28 AM
jsaredwings's Avatar
Default Re: How to get INTO the fog light
BUMP, i just got into the same situation
Old Oct 14, 2012 | 08:25 AM
Originally Posted by nickwe21
Hey guys!
Nick
Different bulb, fog/driving light bulb #9006.
You will have to get the light out and shake the glass out. Access is through the flap in the fender liner. But it will be easier to remove the whole light by removing the lower fender liner. I am not sure if the main fender liner has to come out as well though. Have a look at the Repair Manual which is available on this site as a download. See the SRT6 documentation Sticky thread.
Old Oct 14, 2012 | 09:17 AM
Jack the car up, support it and remove the front wheel.
Remove the fender liner flap.
Unplug the light connector.
With flashlight and I think a T20 Torx remove the 3 securing screws, the unit will then come out through the flap.
Old Oct 14, 2012 | 10:32 PM
Buck Spunni's Avatar
I was able to get the light out working through the access panel with the wheel turned for clearance. Bolts are fairly easy to find by feel.
xfireohio
Jul 20, 2020 12:03 AM
Adrian_X
Nov 9, 2017 08:49 AM
maxcichon
Jul 8, 2016 08:28 AM
pioneer4x4
Sep 24, 2015 11:17 AM
KwehCat
Jul 16, 2015 04:48 PM
