Top mechanism
Old Sep 26, 2012 | 01:14 PM
Furgal's Avatar
Default Top mechanism
Yesterday, my top failed to go up. The cover lid rose up, but the top would not move and there was a whining noise. I followed the instructions to manually raise the top and that worked, but does anyone have an idea as to what may be wrong? Thanks!
Old Sep 26, 2012 | 01:36 PM
Default Re: Top mechanism
Sounds like low on fluid or a bad pump?
Old Sep 26, 2012 | 02:35 PM
Furgal's Avatar
thanks for the help.
Old Sep 26, 2012 | 02:43 PM
If the pump kept running, then it was probably low fluid.
But it can also be a bad sensor on one of the cylinders that raise the lid, not "telling" the TCM to "change gears" when the cylinders get fully extended. When they do fully extend, sensors tell the TCM that this has happened, and the pump valves switch to:
1) Maintain pressure in the lid cylinders so the lid stay up.
2) Pressurize the cylinders that lower the top.
Sounds to me like the sensors on the lid cylinders are not telling the TCM to "change gears", but it is hard to say without being there.
Check the level of the fluid AT THE POINT IT ALL STOPS WORKING, there should be a partial tank of fluid at that point. I believe it will be over 1/2 full, I'll check when I get a minute and tell you what mine looks like at the particular moment.
Old Sep 26, 2012 | 07:39 PM
RMADERMAN's Avatar
I have had to replace the drivers side lift cylinder. The seal was leaking.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
MickeyNasty
Sep 6, 2015 08:29 PM
