Headlight Condensation
Old Oct 7, 2012 | 11:32 PM
smokey847's Avatar
Default Headlight Condensation
I know this has previously been discussed at length, but I suspect my situation may be more specific. The other day, after some rain, I noticed condensation inside the driver's-side headlight assembly. I recall when replacing the eyelid bulbs knocking a small yellow thing off of the back of the headlight. I covered the hole with electrical tape. What was this and could this be the reason?
If so, what is it called so that I can order a replacement? Would prefer not to deal with the dealer and a TSB kit.
Old Oct 11, 2012 | 01:45 PM
smokey847's Avatar
Default Re: Headlight Condensation
Just noticed today that that the inside of the headlight has a watermark, where it looks like the tiny condensation beads have dried. Could someone please offer a solution? Thanks!
Old Oct 11, 2012 | 02:03 PM
maxcichon's Avatar
https://www.crossfireforum.org/forum...tml#post659138
Old Oct 23, 2012 | 04:36 AM
Steve - UK's Avatar
This subject has been widely covered with methods for cleaning inside dirty lenses discussed in detail.(thanx maxcichon) What about preventing a re occurance of the misting problem? Im sure there must be owners who are still experiencing this problem with the misting coming and going.
Old Nov 20, 2012 | 12:16 PM
Steve - UK's Avatar
Im just experimenting by leaving the rubber covers off the back of the main beam aperture on the back - headlight seems to be staying mist free
Old Nov 20, 2012 | 12:57 PM
maxcichon's Avatar
There is a $25 kit that includes caps with permeable membranes. Allows the cases to breathe.
Old Nov 20, 2012 | 01:28 PM
Buck Spunni's Avatar
Headlight seal & cap kit, #05174786AA
Old Nov 20, 2012 | 01:40 PM
Here is half the kit and the parts it replaces. Serious amounts of water may be leaking around the lens seal or elsewhere. I saw one Crossfire on the Dragon and goldfish could have survived in the headlamp unit.
(Click to enlarge)
Old Jun 14, 2022 | 08:08 PM
richb55's Avatar
cant find these parts anywhere 🙄. Any suggestions or alternative solutions ?
Old Jun 15, 2022 | 08:44 AM
Anything that can almost totally 'seal' the assembly from moisture, then before installing them (in the sun facing them towards it), use a hair drier on low & aim the thing into one of the opened lamp covers until you get everything inside very warm. Then, while it is still very warm inside the lamp assembly (you might need an extra hand or two), cover/seal the openings. Do that to the other one and you should be OK.
Thats about the only suggestion I have short of finding a 'kit' somewhere. I am guessing you already made sure those rubber 'vent covers' are intact, with that little foam piece inside them (and you have the rubber covers behind the lamps installed afterwards)? Good luck!
Old Jun 15, 2022 | 08:59 AM
richb55's Avatar
[QUOTE=GraphiteGhost;969361] Anything that can almost totally 'seal' the assembly from moisture, then before installing them (in the sun facing them towards it), use a hair drier on low & aim the thing into one of the opened lamp covers until you get everything inside very warm. Then, while it is still very warm inside the lamp assembly (you might need an extra hand or two), cover/seal the openings. Do that to the other one and you should be OK.
my local dealers response
Here’s how my search was going 🙄]
Old Jun 15, 2022 | 11:24 AM
Ronman's Avatar
[QUOTE=richb55;969365]
Most of the parts that are Crossfire specific are discontinued/NLA for more than 4 or 5 years now.
Old Jun 15, 2022 | 11:36 AM
richb55's Avatar
[QUOTE=Ronman;969368]
the Quest continues , hopefully Mercedes could shed some light on the subject 🙄
thanks 👍
Old Jun 15, 2022 | 12:08 PM
Not likely, the headlights are Crossfire exclusive.
Old Jun 15, 2022 | 12:17 PM
Ronman's Avatar
[QUOTE=richb55;969369]
thanks 👍
Mercedes has basically been done with Chrysler since 2008 or so. They don't have any similar kits for headlights that I have ever seen. Maybe another auto maker that uses Valeo to make their headlights but that is unlikely.
Old Jun 15, 2022 | 02:07 PM
richb55's Avatar
[QUOTE=Ronman;969374]
I guess this is where my “special set of skills”
Will be required 😎
Old Jun 15, 2022 | 03:18 PM
Below is a photo of the kit that Chrysler sold to rid the headlights of the condensation problem. It shows the parts for one headlight, the new cover and the two caps that completely covered the holes where the 'T' shaped breathers fitted originally. There was two of these kits required, I am not sure if they came in a single kit or if two kits were required. I never really had the problem but I fitted the kit anyway. You can see the rectangular insert that prevents the ingress of water and provides an outlet for water vapour.
I have an idea that a square could be cut in two of the covers, one for both sides, and a piece of Gore-Tex or a similar material glued over these holes with the rainproof side on the outside and the breathable surface inside. Or is there some other material that would be better?
The two 'T' shaped fittings being replaced with rubber plugs like those shown in the kit above.
The idea being that water would not get through the Gore-Tex and water vapour could escape through from the inside. Obviously the air inside the headlight unit would expand when heated by the bulbs driving air out, my question on this is would the air escape fast enough to avoid blowing the cover of and let air pass back into the headlight when it cools down.
Some headlights in the past have had leaks in the sealant allowing water to get into the headlight, I saw one headlight at the Dragon in 2010 with enough water in it to keep a goldfish alive, it must have had a bad leak somewhere.
Old Jun 15, 2022 | 03:53 PM
richb55's Avatar
[QUOTE=onehundred80;969382]Below is a photo of the kit that Chrysler sold to rid the headlights of the condensation problem. It shows the parts for one headlight, the new cover and the two caps that completely covered the holes where the 'T' shaped breathers fitted originally. There was two of these kits required, I am not sure if they came in a single kit or if two kits were required. I never really had the problem but I fitted the kit anyway. You can see the rectangular insert that prevents the ingress of water and provides an outlet for water vapour.
Some headlights in the past have had leaks in the sealant allowing water to get into the headlight, I saw one headlight at the Dragon in 2010 with enough water in it to keep a goldfish alive, it must have had a bad leak somewhere.[/QUOTE
that sounds like it could work , I’ll try and locate
some gortex fabric , plugs should be easy enough to locate 👍
many thanks 😉
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
RacerXofFL
Sep 15, 2015 05:00 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
