Keep fogs on when high beams on?
Old Nov 26, 2012 | 08:41 PM
stryfox's Avatar
Default Keep fogs on when high beams on?
Before people start yelling about the law I am aware you are only allowed to have 4 forward facing lamps lit at one time.
Here is what I would like to do.
I would like the fog lamps to stay on when the high beams are turned on.
There must be a power or ground that is sent to the fog lamps when the high beams are turned on to switch the fogs off.
Anyone have a diagram or info on this?
Thanks for any input.
Old Nov 26, 2012 | 08:57 PM
waldig's Avatar
Talking Re: Keep fogs on when high beams on?
Never heard that, are you sure?? Woody
Old Nov 26, 2012 | 09:00 PM
stryfox's Avatar
Default Re: Keep fogs on when high beams on?
In the USA I am pretty sure. That is why the fogs turn off when the high beams go on.
At least that is what I learned back in 1993 ish when I got my Pennsylvania state inspection license.
Old Nov 26, 2012 | 09:09 PM
stryfox's Avatar
Ok, I just read pa Code 175.66 online.
It is diffrent than the old printed copy I have.
Dam you need a layer to red this stuff now. Hahaha
Anyway, not really interested in the legal aspect.
I really just want the fog lamps to stay lit with the high beams on.
Old Nov 26, 2012 | 09:18 PM
waldig's Avatar
So hook them up and go, Your not trying to hook them to the light are you?? Just use a relay, two exactly. One on high one on low both in parallel. wHEN LIGHTS ARE OFF, FOGS ARE OFF.
Durn cats
This will not overload the light circuits and still does your deal with relays and a fuse of course. Woody
BTW it would be good to go to the HID's as thats more light and Id suggest 55w HIDs for the low beams , the HIDS are slow to start and makes flashing the hi's difficult. WW
Old Nov 26, 2012 | 09:27 PM
stryfox's Avatar
I have hid in the lows.
I could run some relays, that would work.
I am assuming when you turn on the highs it drops a ground or a hot for the fog relay.
If I had a diagram I might just be able to disconnect it or bypass it and not have to run any new relays.
Old Dec 2, 2012 | 03:46 AM
Jackerman's Avatar
If you manage to be successful please post pics and show us , I've wondered the same thing
Old Dec 2, 2012 | 06:04 AM
I have 3 million miles on the road....and unless this is just for looks, you get nothing from it... And, if you really wanted to do this, you could go to a dedicated switch as well.
Old Dec 2, 2012 | 06:36 AM
The fogs are controlled by the ICM ( Illumination Control Module -ie, the light switch assembly ).
Pin 20 supplies 12v for the left fog, pin 21 for the right ( LHD models ).
There is no internal wiring schematic for the LCM to my knowledge.
Old Dec 2, 2012 | 10:05 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
JMO : Get rid of the HID's in the lows and replace with the Osram 65W "off road' bulbs that were posted here about 6 months ago. Greater light, farther throw and no-one has given me their high beams thinking I have mine on. Cheap mod and well worth it.
Old Dec 2, 2012 | 11:06 AM
I pm'd you on your opinion on these bulbs a few weeks ago, so you like them I guess. I have had some (4 of them) for way over a year now, I got them after reading about them, I posted the material 18 months ago. I got another 10 cheapos from China or wherever. I should be good for a while.
I guess I'll put them in, I never did like the HID's and never installed them in this car.
I was waiting for a guinea pig.
Old Dec 2, 2012 | 11:10 AM
Sorry Dave.....I thought I got back to you.
I think they are great....love em.
I'll buy a set from you if you have extras!!!
Old Dec 2, 2012 | 11:15 AM
For you, no charge.
Old Dec 2, 2012 | 11:16 AM
Send me a set, I'll be your guinea pig.
Ooops, guess thats a no...
Last edited by GraphiteGhost; Dec 2, 2012 at 11:18 AM. Reason: Read the rest of the posts
Old Dec 2, 2012 | 11:18 AM
For you, no charge.
You sir are too kind. Timmies on me when we get together.
Old Dec 2, 2012 | 05:07 PM
Love da coffee ...
Old Jun 4, 2013 | 06:41 PM
nullmeatbag's Avatar
I guess this is an old thread, but I'm looking to do the opposite of this.
So far, I've done what stevedask advised in this thread (which turns the fogs on when the ignition starts). The only problem now is getting the fogs to turn off when the high-beams are on.
Anyone have any ideas?
Valk
Jul 12, 2021 09:49 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Oct 1, 2015 01:42 AM
ala_xfire
Sep 28, 2015 05:51 PM
Franc Rauscher
Sep 20, 2015 09:35 AM
