LED license plate bulb -- full assemblies
Old Dec 7, 2012 | 12:02 PM
JHM2K's Avatar
Default LED license plate bulb -- full assemblies
Anyone think these would work?
License Plate SMD LED Light No Error Mercedes W203 C230 C240 C280 C320 C32 C55 | eBay
Going off memory, I think these are roughly the same shape as the OEM lenses. My plastic lenses are cracked, and I've tried numerous "flicker-free" LEDs that end up going on the blink in ~2 months. Seems replacing the whole housing would make the most sense, and the reviews on the Benz forums are pretty positive.
Cheers,
Old Dec 7, 2012 | 12:46 PM
IBLUBYU's Avatar
Default Re: LED license plate bulb -- full assemblies
Cheers,
These look like they are sealed units and may have no option to change just a bulb. If they do indeed fit, they could be a good option if you insist on LED lighting. Otherwise, Dave (180) has posted a diagram and plan for making a DIY lense, to replace the cracked lenses. If your OEM units still get power and light the bulbs, this might be an option. Just sayin..... If you get them let us know
Old Dec 7, 2012 | 04:46 PM
JHM2K's Avatar
K, I compared the shape to the ones on my car, and it's bang-on.
I also ran the OEM part number (A 230 820 02 56) and it's used on nearly every Mercedes from C320 to SL65 AMG. So, these should fit.
I will likely get a set ordered and update the thread with pics/how-to.
Old Dec 7, 2012 | 04:49 PM
JHM2K's Avatar
Over the winter, I'll be upgrading all lighting to LED and HID.
I ran LED bulbs on my white Limited, and it simply made the car look "newer" at night.
I need to get busy with the search tool, to find out what everyone is using for marker lights up front w/o throwing error code.
Old Dec 7, 2012 | 05:12 PM
This looks like a great idea. Cheaper than buying lenses at $15(?) each. So the price is right.
Old Dec 7, 2012 | 05:27 PM
JHM2K's Avatar
My thoughts as well. That's why I'm really hoping this works properly.
Old Dec 7, 2012 | 09:51 PM
JimmySkullz's Avatar
I dont know if anyone else posted these, But I have them in both my Crossfires, over a year now with no problems. A little bit of a tight fit but they work perfect.
2 License Plate LED Kit No Error Mercedes W211 S211 E Class W219 CLS R171 SLK 55 | eBay
Old Dec 7, 2012 | 10:15 PM
I just ordered this set..
If Jimmy says he has them in his Crossfires then I'm hoping they work for me
Pulling up our model it says neither these or the ones John posted fit but Jimmy says they do so the proof is here
Thanks for the thread and the info here guys
Old Dec 7, 2012 | 10:29 PM
Yep, Had no problems with them
Old Dec 8, 2012 | 02:10 AM
JHM2K's Avatar
This is kinda what I was expecting once I saw that the A 230 820 02 56 housing was used on dozens of MB platforms over the last decade. I'd be willing to bet good money that there is no difference among the sets offered by that eBay seller, just differences in the auction listing.
Glad you've got a working set, and have had great success, Jimmy! This gives me the vote of confidence I need.
Any tips on removing the old ones?
Old Dec 8, 2012 | 11:47 AM
Cool!Mine came out fairly easily once I removed the lens the housing is just snaped in , I think there may have been some 3m tape or something.
Old Dec 9, 2012 | 08:01 PM
smokey847's Avatar
Keep us posted, JHM2K. My lenses are cracked and crappy. Plus, the drivers' side bulb works intermittently for some reason. Thanks!
Old Dec 10, 2012 | 09:20 PM
Fjp3105's Avatar
Just ordered the same kit Jimmy linked. Hopefully all goes perfectly. Will report back.
Old Dec 10, 2012 | 10:13 PM
JHM2K's Avatar
Min have been ordered, should see them between the 12th and the 14th.
Old Dec 11, 2012 | 10:31 AM
dtinker's Avatar
Just ordered a set of these, Should know how they are in a week or so!
Old Dec 11, 2012 | 03:20 PM
Damn.
I got new lenses from Rob a few months ago and did the LED conversion when I forst got the car. When one of the bulbs goes, I will move to this, thanks for the info, gentlemen!
Old Dec 12, 2012 | 07:15 PM
I ordered these and got them today !!
A very simple install and WOW what a HUGE difference
Great LED replacements for our OEM's
Just remove the old covers and then pry out the OEM sockets and simply unplug the wire and plug it into the new LED assembly and snap the assembly back into the hatch. They fit perfectly !!
No screws even needed any more and the light is crisp white !!
OH YA....No bulb out indicator on the dash either
All Pics Here>>>
Old and New comparisons etc
OEM Sockets and covers
Old Dec 12, 2012 | 07:47 PM
Got them today !!
All Pics Here>>> LED license plate bulb -- full assemblies
the Illinios Highway Patrol thanks you for your service...
Old Dec 12, 2012 | 07:56 PM
Mrmiata's Avatar
Big help for the "old timers" huh Doc?
Just almost pulled the trigger on these.. then thought.. do you need them or just want them.. LOL
Old Dec 12, 2012 | 08:21 PM
JHM2K's Avatar
Gary, I'm stoked they worked out good! This rocks
