Headlamps
Old Nov 20, 2013 | 12:57 PM
Padgett's Avatar
Default Headlamps
The operator's manual calls out an H7U headlamp. Does it use the same bulb in all four ? (Hi and Lo beam) ?
Just called Sylvania/Osram and they say the SilverStar Ulras meet the German "U" standard..
Old Nov 20, 2013 | 01:01 PM
Default Re: Headlamps
Same bulb for all 4.
Any H7 will work, don't know about the yellowing, if you are referring to the headlight covers, then that is caused by the sun's UV.
Apparently the "U" is a special coating to prevent yellowing of plastic reflectors Does anyone know if the Sylvania/Osram Silverstar Ultra has this coating ?
Thank you,.
They are the same high and lows. I think the U is basically universal, especially the name brands.
Search for forum users history with Silver Stars, it is not too bright, I guess that's a pun.
Old Nov 20, 2013 | 01:10 PM
When you make a pun without realizing it, then that is an unpun, or a nonpun, or a nullpun ; take your choice
Old Nov 20, 2013 | 01:21 PM
I regularly make puns, so I guess that makes me punctual.
amcordo
Jun 4, 2023 12:48 AM
05roadsterguy
Jun 10, 2015 01:04 AM
Electric Messiah
Nov 28, 2007 03:12 PM
WildChild
May 1, 2007 09:07 AM
BullFrog
Feb 19, 2006 07:34 PM
