Headlight Lense Inner Condensation
Old Dec 12, 2013 | 03:38 PM
carjock's Avatar
Default Headlight Lense Inner Condensation
My "new" 2006 roadster has condensation inside the headlight lenses that tends to get worse in cool, wet weather. It builds up a "moisture film" on the inside of the lense that not only looks tacky, but can affect the headlight intensity. How does one remove the outer lense to clean the inside of them, and what could be causing the ingestion of moisture in the first place?
Old Dec 12, 2013 | 04:52 PM
JesseJamessrt6's Avatar
Default Re: Headlight Lense Inner Condensation
you don't remove the outer lense. search for it with the search tool here it really works.
https://www.crossfireforum.org/forum...ight-lens.html
Use a hair dryer to dehydrate the moisture be removing one of the black caps at the back of the light. Get the TSB condensation headlight caps to replace the OEM vents (2 per headlight) if that doesn't fix it then you are getting water in from somewhere else possibly a crack.
Old Dec 12, 2013 | 05:15 PM
see this for cleaning the inside of the lens :
https://www.crossfireforum.org/forum...-assembly.html
Old Dec 13, 2013 | 05:12 AM
carjock's Avatar
Where do I get the TSB headlight condensation caps?
Old Dec 13, 2013 | 06:01 AM
Here is one source :
05174786AA Mopar HEADLAMP SEAL KIT $19.24
Old Dec 13, 2013 | 08:56 AM
My local Chrysler dealer had them
Old Dec 15, 2013 | 01:58 PM
carjock's Avatar
I ordered the TSB lense kit, We'll see how it works. Thanks for the input!!
Old Dec 23, 2013 | 02:12 PM
smokey847's Avatar
I've been procrastinating about doing the methanol method. Let me know how this all works out for you please.
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
gp1200x
Dec 6, 2015 12:59 PM
RacerXofFL
Sep 15, 2015 05:00 PM
