Rear Light Cluster - Orange Light bulb
Old Jan 26, 2015 | 02:59 PM
TerryR's Avatar
Default Rear Light Cluster - Orange Light bulb
I had the need to remove my drivers side rear light cluster, and when removed, noticed that the Orange Light bulb was looking a bit worse for wear. By that, I mean the bulb appeared to have had an orange coating on the outside of the bulb glass which had cracked and flaked off in places, so decided to replace it. I bought the bulbs at the Local Auto Spares shop, but had difficulty inserting the bulb. On investigation I found that the pins on the stem, for lack of better words, were offset on the diameter, which is the reason they would not fit. I have never seen this before. I HAVE seen in the past, these pins offset in the length of the stem, which is what I always check for BUT never this way ?????
Have these GOT to be a Dealer Part ????? STRANGE TO ME
Old Jan 26, 2015 | 03:11 PM
Default Re: Rear Light Cluster -Orange Light bulb
It's a 7507 bulb :
Old Jan 26, 2015 | 05:56 PM
TerryR's Avatar
It's a 7507 bulb :
Thanks for the info. I will see if I can locate some.
Old Jan 26, 2015 | 06:48 PM
Bill F's Avatar
Found it:
https://www.google.com/url?sa=t&rct=...zwaPv00ALbAg1Q
Old Jan 29, 2015 | 05:06 AM
TerryR's Avatar
Originally Posted by Bill F
Thanks for the Info BillF, Finally found some locally, bought, fitted AND done now. See Ya'll SOON
Old Jan 29, 2015 | 06:22 PM
DTMenace's Avatar
Terry
You may want to eliminate the "Egg Yolk Look", these bulbs eliminate the yellow look through the clear plastic lenses, front and back. They do flash Amber, meeting all legal requirements for each state inspection in the USA. I have these on my SRT6 and it looks much cleaner, even though they are a little pricey.
Just my 2 cents......
Dennis
DTMenace
h
ttp://www.amazon.com/7507-Chrome-Amber-Bulb-Pack/dp/B0090WUSQU ttp://www.amazon.com/7507-Chrome-Amber-Bulb-Pack/dp/B0090WUSQU
Old Jan 29, 2015 | 07:06 PM
What he said. I have the chrome/amber bulbs too, and they look much nicer, AND the orange paint don't peel off, cause there ain't none .....
Old Jan 29, 2015 | 07:58 PM
JEFASOLD's Avatar
They are both correct and while you're at it you can do the fronts also, and don't forget to remove the tail light assembly and empty out the flakes that will be lying in there.
Old May 11, 2015 | 08:26 PM
Chiminoul's Avatar
Default Re: Rear Light Cluster - Orange Light bulb
What type of light is that? It seems that both my "middle" rear lights aren't working.
2004_
Jul 9, 2025 12:39 AM
Hoppy
Dec 7, 2018 07:36 AM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
KwehCat
Jul 16, 2015 04:48 PM
