Custom headlight assemblies, 3D printed housing.
Old Apr 22, 2024 | 01:00 AM
MAYAman's Avatar
Default Custom headlight assemblies, 3D printed housing.
I'm creating some updated headlights for the crossfire with morimoto parts. I 3D scan the housing so that I can do some alterations to it and then print a new housing while still using the factory lenses. So far it's coming out pretty cool.
Old Apr 22, 2024 | 10:30 AM
Default Re: Custom headlight assemblies, 3D printed housing.
I wish you well on your endeavours.
Old Apr 22, 2024 | 05:12 PM
MAYAman's Avatar
Thanks 😁
Old Apr 23, 2024 | 07:59 AM
xintersecty's Avatar
Is there a way of printing a new clear front lens? If so then we can actually build new headlights.
Old Apr 23, 2024 | 09:29 AM
You need clarity, so stretch forming a clear sheet would be a good method. Forcing a mirror finished core into a hot sheet of plastic using heat and vacuum etc. would be one way. Opting for a flat lens with sides bonded to the back face would be the simplest.
Old Apr 23, 2024 | 10:03 AM
I should have been more respectful to the original poster @MAYAman and complimented his fine work and research. We need more stuff done like this to keep our cars on the road considering it's such a niche market. So thanks and the work your doing is very nice.
This might be the best method of construction for small shop makers. Heat and vacuum form the font lens as a curved plane. Print the support form that interfaces the lens to the back housing. Glue those two parts together. Then that assembly can clip to the housing.
Old Apr 23, 2024 | 11:40 AM
That is a great idea, the lens does not to have to be too thick. Polycarbonate (Lexan) is an ideal lens material and what they are now I believe.
Old Apr 24, 2024 | 12:09 PM
MAYAman's Avatar
FYI I'm experimenting with different methods (vacuum form, molds, heat molds, etc. Once I'm done with the mounts and housing I'll move to the lenses.
Sdill05
Aug 28, 2022 09:10 AM
Joliet John
May 3, 2017 01:30 PM
STEPHENJXN
Detail Shop
Jun 26, 2014 02:22 PM
samed11
Aug 17, 2012 11:55 PM
Monopoly_Man
Jan 7, 2008 01:29 PM
