Illumination control module failure
Old Mar 21, 2026 | 09:47 PM
oxoman's Avatar
Default Illumination control module failure
Has anybody experienced repeated failure of the illumination control module/light switch? Replacement units work okay for a month or two, then they burn out without blowing any fuses.
Old Mar 23, 2026 | 01:00 AM
Default Re: Illumination control module failure
There are no fuses going to the ILM. Power comes directly from the bus fuse located in the small black box near the battery.
You might want to do the inline fuse fix. If the ILM is messed up it could cause a fire. Installing inline fuses can help prevent that and may help to isolate your trouble.
Here's my post on how to do the inline fuse fix: ILM Inline fuse fire prevention
Old Mar 23, 2026 | 09:37 AM
zip439's Avatar
I would try to find the source of your problem.
With everything turned off place a amp meter between the cars battery ground fitting and the negative battery terminal. Pull the lighting fuses on the side of the dash until the amps drop to .05 or less. The fuse that causes the amp drop is the wiring that has a problem. Fix that and you will stop burning up your illumination module. Here is a link to detail Pizza's Tech Help
The inline fuse is of course also a good suggestion while you are in there making repairs.
Docsgwc
Jul 6, 2021 10:23 AM
Shamrock
Dec 2, 2016 04:45 PM
Jonathan82
U.K.
Aug 19, 2010 05:40 PM
Steenport567
Nov 13, 2008 05:48 AM
