battery trouble
Old Mar 19, 2009 | 09:33 PM
rem-lor's Avatar
Default battery trouble
I left my car stored for two months and forgot to disconnect the cables.
The battery is now dead.
We tried to charge it but it wont charge at all.
Do I need a new battery or does it have something to do with the charging system?
Any help would be greatly appreciated.
Thanks
Lee
Old Mar 20, 2009 | 06:30 PM
bluecoupe's Avatar
Default Re: battery trouble
I had the same problem. My battery went dead (left the interior light on) and it wouldn't take a slow charge. Fluid levels in the cells were right up so I took it to have it tested. It was put on a quick charger for just a few minutes and the machine kicked off and the tech told me the battery wasn't any good, won't take a charge, so I took it home. I thought I'd try the slow charge again cause I read somewhere that if a battery discharges slowly then it needs to be charged slowly. Hooked up the slow charger and hey, shot right up to 4 amps. Eighteen hours later the battery is fully charged and appears to be holding the charge. I've put the slow charger back on it few times mores after it has been sitting for a few days usually starts off at 1 or 2 amps and within a few minutes the meter says it's fully charged. So far so good. It's coming up for 4 years old so I'll be switching it out for a new one in the not too distant future.
Old Mar 20, 2009 | 06:48 PM
What year is your car? It could be ready for a new battery. This thread might help:
https://www.crossfireforum.org/forum...ad.php?t=29511
Old Mar 20, 2009 | 11:24 PM
Available at Firestone
$20 off coupon here...http://www.firestonecompleteautocare...fers/index.jsp
Battery Replacement - Interstate MTP-91
Old Mar 21, 2009 | 09:10 AM
70GT6's Avatar
If you want to maintain the factory look, the direct replacement "semi transparent" battery is MTP-H6 (cost is a bit more)
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
