PC question.
Old Jun 20, 2004 | 03:25 PM
LVXFIRE's Avatar
Default PC question.
I am sorry to post this un-crossfire related subject, but I am in a quandry and need help. I know many of you are quite knowledgable of PCs so here goes...
A couple of days ago I started getting pop-up ads. I have heard this is common so it did not worry me. One thing I did not notice right away is that for some unknown reason my home page changed to some sort of search page. There is no identifying information on the page. I right click all over the page and it does not bring up the properties window at all. I have tried to change the homepage default and it just switches itself back to this new page. Another issue with it is that on other pages, it will highlite keywords and when you click on the word it takes you to that sites search results on that word. When I perform a search on Yahoo! a seperate window pops up with that sites results.
This is driving me insane! :cry:
I have defraged, disk cleanup, cleared cookies, deleted temporary files, cleared history, installed spy bot and ad-ware.
Have any of you seen this before? What can I do?
Thank you in advance. I really appreciate you taking the time to help!
Old Jun 20, 2004 | 03:50 PM
Cheebs's Avatar
Default
Do you have Norton or McAfee?
Old Jun 20, 2004 | 04:00 PM
Guest
Guest
Posts: n/a
Default
Welcome to the world of "hi-jack" software, I just cleaned my daughter's system of this stuff. Norton or others can help you remove it. You can also
look for packages that are installed on your system, "My Way" or something along that name, also "Open Site" is another, remove them.
Old Jun 20, 2004 | 04:04 PM
Cheebs's Avatar
Default
and if that doesn't work you might have to reformat. You could try a system restore but I doubt that would do it.
Old Jun 20, 2004 | 04:48 PM
Cruiser's Avatar
Default
Hi,
You might want to download a program called Adaware...http://www.lavasoftusa.com. Look at the left top section, and download the 3rd one down.
It will detect those tracking sites that are following you. After you run the program, click on all that it shows...then delete them.
I run this program, at least once a week. And it's free!!
Old Jun 20, 2004 | 07:41 PM
houstondan's Avatar
Default
http://www.komando.com/
try that site. kim kommando has a radio show dealing with that kind of stuff and she's got a bunch of ways to attack your problem. all free.
if your operating system has a "system restore" like xp or "go back" like some gateways, you can revert the drive to a time before the trouble started. you will lose anything done since then but you'll be clean.
good luck
dan
Old Jun 20, 2004 | 07:50 PM
drunkiq's Avatar
Default
Go to the spysweeper site and download the free one - it should scan the memory and clean it out. You will probably freak out on how much spyware you actually have on your system. I have not tried the adaware that was suggested yet...
http://www.spysweeper.com/
-marc
btw - this belongs in the off topic folder...
Old Jun 20, 2004 | 07:52 PM
knowit's Avatar
Default
Adaware is the best. I have fixed many systems that were thought to be unfixable with this program. And I am a pc technician and I swear by it.
Old Jun 20, 2004 | 08:14 PM
Cheebs's Avatar
Default
ad-aware is great but LVXFIRE said she/he has it. I'd do a system restore and if that doesn't work you're probably gonna have to reformat. What kind of computer do you have?
Old Jun 20, 2004 | 08:39 PM
drunkiq's Avatar
Default
you should never have to format a hard drive, there are many, many alternatives to that...
first try another program... at worse you would have to check some spots in the registery to see what is going on but i have yet to see an add pop-up program that spysweeper did not find lingering in memory. Also go to google and download the google bar, it is the best pop up blocker I have yet used.
-marc
Old Jun 20, 2004 | 08:57 PM
Cheebs's Avatar
Default
-marc
Huh? I would reformat my hard drive every 8-12 months.
Old Jun 20, 2004 | 10:35 PM
qtrfoil's Avatar
Default
Cruiser, I finally figured out that you can right click in the box that shows "Found Objects" and select tham all. Ad Aware 6.181, at least.
Old Jun 20, 2004 | 10:55 PM
drunkiq's Avatar
Default
you can get a fresh install of windows if that is what you are thinking with out FORMATTING your hard drive... why lose all the data?
-marc
Old Jun 23, 2004 | 11:06 PM
leebea's Avatar
Default
I get that same search page (about:blank) and can't get it off my computer. I bought and used SpySweeper on the advice of CompUSA. It is better but is still there. SpySweeper lets me not use it as my default home page so it's in the background and out of the way.
If you find a way to make it disappear, short of formatting the hard disk, please post it.
Thanks and good luck,
Old Jun 24, 2004 | 12:54 AM
Cruiser's Avatar
Default
Hi Leebea,
I am kinda confused. Are you trying to get your home page, thru Internet Explorer to be a certain page? Like Google for a search engine? You can change your home page by going to your Start button, then Settings, then Control Panel, then Internet Options, and change it there.
If that is not the problem, please post again, what you what to change. We will see if one of us can help again
Old Jun 24, 2004 | 06:54 PM
leebea's Avatar
Default
Cruiser, I did that and "about:blank" would reset itself as the default every time I hit the "home" key or restarted the computer. It doesn't do it anymore since I installed SpySweeper. It's still there but not active. I'm ok with it so long as it doesn't bother me. I still get the popups that say my computer may have spyware but I just close them.
Old Jun 24, 2004 | 07:01 PM
Cruiser's Avatar
Default
Somehow I got Spysweeper starting on my computer, it was running, sh owing me tons of spyware it found. But before I wanted to buy it, I ran Adaware....seems Adaware caught all that Spysweeper had, and at no cost.
Try running Adaware again, delete all it finds and see if they go away Is sure like Adaware <g>
Old Jun 26, 2004 | 11:32 AM
David Burns's Avatar
Default
Good article about spyware and suggestions how to deal with it:
http://www.wired.com/news/infostruct...,63978,00.html
gblack32
Sep 7, 2016 08:27 PM
Charlesl
Sep 30, 2015 10:46 PM
Tommyj
U.K.
Aug 31, 2015 10:45 AM
Clive
Europe
Jan 7, 2008 08:48 AM
patpur
Oct 8, 2005 04:30 PM
