Keeping Headlights Clear
Old Jun 21, 2014 | 04:17 PM
Donna H's Avatar
Default Keeping Headlights Clear
Hi, My husband has just finished liquid sanding the headlights and they now look really good. Does anyone have any suggestions as to how to keep them that way? A clear coating of something? Plastic cover-up sheets of some sort? Thanks!
Old Jun 21, 2014 | 04:57 PM
Default Re: Keeping Headlights Clear
Some people have clear coated them and others use liquids meant to preserve them. Still others have applied a thin film of special plastic. Maybe someone with more knowledge will answer you.
Old Jun 21, 2014 | 05:09 PM
I installed XPel ( 3M ) covers 3 years ago, mine are still nice and clear.
Autoanything, $49.99, free shipping and a 15% discount = $42.50 ( includes fog covers also )
NOTE: there were some small bubbles after the initial installation, took almost a whole month for them to go away ......
Old Jun 21, 2014 | 07:21 PM
Donna H's Avatar
Thank you very much for the info! I have just checked and there is a place in Oakville that sells xPel...I will contact them to make sure they have 2004 Crossfire ones and compare the prices to Autoanything. Thanks again!!
Old Jun 21, 2014 | 09:05 PM
A dose of PlastX on them every month or so during the summer, and mine still look good after 4 years.
Old Jun 21, 2014 | 09:12 PM
PNA's Avatar
PNA
I use wax on mine. Clean as new. Car is 11 years old next month. I only have 532know on it and it is garage kept though..
Old Jun 21, 2014 | 10:56 PM
Donna H's Avatar
All great suggestions - thank you! I hadn't thought of wax... Thanks!
Old Jul 17, 2014 | 01:00 AM
Bay Cruise's Avatar
Did you have any photos before and after ?
Old Jul 17, 2014 | 03:02 AM
syfi's Avatar
Here's what the pros use. Was used on mine and 4 yrs later they still look showroom new. UV-cured coating makes all the difference. LIFETIME WARRANTY!
Link: UV Lightrite Headlight Restoration Products And Headlight Lens Restoration Kit | CureUV.com
Use coupon code LB213 for 10% off all Headlight Restore products.
And you do not need the UV lamps to cure. Sunlight works just fine.
Old Jul 17, 2014 | 11:31 AM
Mrmiata's Avatar
Apparently Duplicolor has a headlight kit now.. facebook member just did hers and looked impressive.. 2 part spray on.
Old Jul 18, 2014 | 04:52 AM
I'll agree with James above. I've treated headlights, fog-lights & tail-lights with Plast-X every 6 months on all my vehicles. This October will be 6 years with the XFire and all of its lights still look like new with no signs of discoloration. Same is true on my 2006 F-150 STX and I've had it 7 years this October.
Now my wife's 2006 VW New Beetle headlights have started getting that haze that's typical. Bought the 3M restoration kit a few weeks back and just need to find the time to spruce up the headlights. Folks claim the 3M kit gives excellent results.
Old Jul 18, 2014 | 01:34 PM
Mine are as new so I have not had to refinish these. I wash them carefully and have used Johnson's wax and Meguiars PlastX on them before.
Meguiars has a product that I am using now called, funnily enough, Headlight Protectant.
Old Jul 24, 2014 | 10:29 PM
Donna H's Avatar
We tried the wet sanding and the PlastX and although they are better, they aren't great. Will try the UV-cured coating restoration kit mentioned above next. Thank you!!
minimayhem
16
Aug 23, 2016 07:47 AM
Franc Rauscher
May 9, 2016 12:04 PM
crossfireusa
Oct 28, 2015 12:03 AM
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
