Help with Chrysler Crossfire History Check
Old Jul 4, 2025 | 09:42 AM
jovoke's Avatar
Default Help with Chrysler Crossfire History Check
Hi everyone,
I’m considering buying a used Chrysler Crossfire and want to make sure I do all the right checks before committing.
I know it's based on a Mercedes platform, but I’m not sure what specific things to look out for when checking its history.
Are there any common issues, recalls, or red flags I should be aware of?
Also, are there particular services or tools that work best for running a comprehensive history report on these cars?
Any advice from current or former owners would be greatly appreciated.
Old Jul 4, 2025 | 09:43 AM
jovoke's Avatar
Default Re: Help with Chrysler Crossfire History Check
Originally Posted by jovoke
Hi everyone,
I know it's based on a Mercedes platform, but I’m not sure what specific things to look out for when using cheap autocheck reports.
thanks in advance for any help
Old Jul 4, 2025 | 11:30 AM
exparamedic's Avatar
These should help you get started.
Jim
https://www.crossfireforum.org/forum...crossfire.html
Old Jul 4, 2025 | 12:01 PM
It's worth the money to get a CarFax report. You'll get a service history, list of locations it was registered to, how many owners.
Seeing where it's been is important. My car has been a north east car it's entire life, so the first thing I looked for was rust. I was very lucky.
If you're buying a convertible, check the seam around the rear glass. Make sure it's not re-glued or falling in. Also check the seams on the rear sides for splits.
Test the top operation, make sure it works up and down. Make sure you have both key fobs if possible. Test drive the car with the radio off and listen for any odd noises.
Old Jul 5, 2025 | 08:38 AM
dcskmail's Avatar
The roadsters rear window glue will fail at some point coming loose from the top, reglueing is a option but not always the best, I replaced my top after reglue failed : Tips when buying a Crossfire https://www.crossfireforum.org/forum...crossfire.html
Old Jul 5, 2025 | 11:10 AM
I reglued mine 11 years ago and it is still fine. The most important thing is proper prep, cleaning and following the instructions on the primer and adhesive. I must admit, living in California may also be a factor.
cirquedaddy
May 4, 2009 05:48 PM
otuzdorton
Jun 23, 2008 10:39 AM
mousegu
Other Cars Etc
May 5, 2008 01:41 PM
imabenz
Apr 18, 2008 07:19 AM
