best way to remove center console/dash cover (silver plastic around radio)
Old Jun 21, 2007 | 11:43 PM
grphtmtlc11's Avatar
Default best way to remove center console/dash cover (silver plastic around radio)
how do you do it without cracking it? start with the top or bottom? take the radio out first?
Old Jun 21, 2007 | 11:51 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: best way to remove center console/dash cover (silver plastic around radio)
i believe it is held in by press clips... i would use a drivers license or credit card and attempt to slide it under an edge and pry gentle... it should begin to release.
Old Jun 21, 2007 | 11:55 PM
blacklimitedcoupe's Avatar
If you remove the radio, you will notice 2 small phillips head screws (one on each side) above the radio opening. You must remove these before trying to remove the silver trim...
Old Jun 21, 2007 | 11:57 PM
andrew's Avatar
~ a good to know...
Old Jun 22, 2007 | 12:00 AM
~ a good to know...
Yeah, I couldn't figure out why I couldn't get the trim loose and then I found those small screws...took them out and it popped right off.
Old Jun 22, 2007 | 12:56 AM
snowtop57's Avatar
Ok, how do you remove the radio?
Old Jun 22, 2007 | 12:59 AM
You need a set of keys/pins that get inserted in the small slots in the radio, and pull out.
Old Oct 14, 2007 | 08:00 PM
Out West's Avatar
FP, can I purchase the radio keys from Chrysler? If so, got any idea how much they charge? Thanks.
Out West
pioneer4x4
Sep 18, 2023 11:49 AM
reiji
Oct 15, 2015 10:50 PM
tom2112
Jul 28, 2015 08:12 AM
Rjono
Jul 15, 2015 03:29 PM
tom2112
Jul 8, 2015 08:13 PM
