Ceiling Cleaning Question
Old Feb 22, 2008 | 04:06 PM
JasonSmith's Avatar
Default Ceiling Cleaning Question
Any suggestions on how to clean a unknown spot in the ceiling of the car and prevent it from damaging the adhesive.
Old Feb 22, 2008 | 04:20 PM
robby363's Avatar
Default Re: Ceiling Cleaning Question
Originally Posted by JasonSmith
Any suggestions on how ti clean a unknown spot in the ceiling of the car and prevent it from damaging the adhesive.
I'd try some warm water and mild dish soap with a clean cloth first.
Old Feb 22, 2008 | 04:50 PM
andrew's Avatar
-C-I-C-C-I Associate Member
i would recommend using a foaming aerosol glass cleaner. (sprayway, 3M, or castle).
spray the foam onto a clean white towel and rub the spotted area lightly to remove any marks.
this is the safest way to complete the task.
Old Mar 5, 2008 | 09:16 PM
irwin's Avatar
yeah you should listen to these guys, i left a can of unopened diet coke in my car on a summer day while i was working (forgot all about it) when i was done with work i came out to a nice little supprise! well little doesnt really describe it, the whole top of the can was blown off and there was brown crap everywhere... except in the can. i cleaned and cleaned but that headliner is a biotch to clean! so i got some resolve... it worked but not fast enough for my liking so i drowsed the headliner in resolve then pulled out the shop vac, yes that was where everything went wrong. now i have a black headliner and black a and c pillars which are much easier to clean!
Old Mar 5, 2008 | 09:37 PM
jonnyangel04's Avatar
DO NOT USE OXY-CLEAN TYPE SUBSTANCE totally ruined my ceiling in my old limited... Although i blamed it on a faulty door seal so stealership replaced both I got lucky do not make the same mistake i did. I had a buddy who used to take stains out of his vette with brake clean I also do not recommend that...
Old Mar 5, 2008 | 10:02 PM
irwin's Avatar
at least we didn't use brake clean lol!
Old Mar 8, 2008 | 09:57 AM
blue pearl's Avatar
Mr. Administrator/moderator, please delete this post, it is duplicated in another thread. When I go into edit I don't find an option to delete, could this be enabled?
Old Mar 9, 2008 | 07:46 AM
irwin's Avatar
wtf?
who are you and why are you trying to get posts deleted?
Old Mar 9, 2008 | 05:46 PM
corfire's Avatar
Actually, brake cleaner works great for removing grease and stains from cloth if use correctly. You spray some on a clean rag and then lightly rub the stain. It basically works the same as dry cleaning fluid. It doesn't leave any residue. That's why it is safe for brakes.
Old Mar 9, 2008 | 06:17 PM
andrew's Avatar
~ just don't ever get that stuff on the cars paint finish... can you say permanent yellow spots.
Old Mar 9, 2008 | 07:07 PM
nox1s's Avatar
unless you have a yellow car!!!
Old Mar 10, 2008 | 02:42 PM
irwin's Avatar
and won't it eat up the foam padding under the cloth?
Old Mar 11, 2008 | 06:55 PM
blue pearl's Avatar
wtf?
GALYAJ
Put your mouse over the EDIT button on one of your posts, then try to read what is says. Other forums allow deleting of your own posts. I don't expect to be able to delete other's posts even though I know whose I would start with..
Old Aug 3, 2008 | 01:46 PM
brewski's Avatar
ammonia based glass cleaner
Jonacross
20
Jul 17, 2017 11:19 PM
Mackel
Oct 16, 2015 09:03 AM
lazorouss
Sep 11, 2015 09:16 AM
jaesa
Sep 7, 2015 01:50 PM
williammt
Sep 6, 2015 11:23 AM
