Replacement bolts for rear interior trim?
Old Oct 13, 2008 | 06:54 AM
samuell421's Avatar
Default Replacement bolts for rear interior trim?
I'll be picking up my very gently used crossfire later this week. It's an '05 with no problems other than about 10 missing interior trim bolts in the rear of the car (and a key fob that looks like it had been run over by a truck). I did a very thorough inspection, a couple times actually, and I'll can can figure is that someone quickly removed some aftermarket equipment (maybe stereo components?) before trading in the car.
In any case, I find myself needing some of these trim bolts for around the rear hatch. Does anyone know where I could find these things at, or where I should start looking? I'm skeptical about going to my only local "chrysler"/dodge/jeep dealer as the only actual chryslers they've had on the lot have been sebrings and town & country's.
Old Oct 14, 2008 | 12:24 PM
nox1s's Avatar
Default Re: Replacement bolts for rear interior trim?
I have a few missing as well, but didn't bother trying to find more..
The best help I can give you is that they're stamped Mercedes... not Chrysler. Try a MB dealer.
Old Oct 15, 2008 | 03:41 PM
ppro's Avatar
What do they look like?
I found a couple types - one is flat like a slightly domed cover and has two holes in it so you can thread them onto studs.
Part - 05103005AA (front ones for carpet behind seats where it meets the top of the bulkhead)
The other is almost the shape of a large push pin without the pin, and threads onto studs.
Part -
05103438AA
It's best you first see a car that has them and then determine location and type before ordering them.
Old Oct 18, 2008 | 05:24 PM
SNAKEWOLF's Avatar
TRY NORTHLAND FASTENERS
http://northlandfasteners.biz/Store/...oducts_id=2426
Old Oct 19, 2008 | 05:40 AM
kingkub57's Avatar
look in the SRT6 area of this forum, and the second banner down is a parts manual you can look up your parts in and maybe get the part numbers you will need
Old Nov 13, 2008 | 05:58 PM
nox1s's Avatar
Originally Posted by SNAKEWOLF
Yeeep. Those look like an exact match, only they aren't stamped Mercedes!
Old Nov 25, 2008 | 03:01 AM
bluecoupe's Avatar
I'm also looking for 1 Mercedes push pin type retainer for the cargo area trim. Is Northland part #N20638 a matching replacement? If so, has anyone got a spare they will sell?
Old Sep 7, 2009 | 05:28 PM
KJN's Avatar
KJN
Default PPRO, Replacement bolts for rear interior trim?
Hi Ppro,
I need the first part you cite, the dome with two holes..Thanks to you I have the part number. Where do you suggest ordering them from the dealer?
KJN
Part -
05103438AA
Old Sep 7, 2009 | 08:28 PM
SRT SIX's Avatar
Had my backup camera installed and noticed most of mine were missing. Went to Autozone and got a pack of 15 by Dorman models 799-100 5/16" (7.93mm). cost was under $5.
Now
SRT SIX's Avatar
Now I
Old Sep 7, 2009 | 08:30 PM
SRT SIX's Avatar
Had my backup camera installed and noticed most of mine were missing. Went to Autozone and got a pack of 15 by Dorman models 799-100 5/16" (7.93mm). Not just push pin, they are threaded with a phillips head. Fit nice and securely. Cost was under $5.
Now I have extra if needed. I am sure they would be at least $5 each from Chrysler.
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Dec 1, 2015 09:02 AM
stlas69
Sep 3, 2015 10:28 AM
mike28117
Jul 10, 2015 10:51 AM
shawnwatson9493
Jul 9, 2015 11:47 PM
