air filter
Old Mar 16, 2009 | 01:04 PM
strikedeep's Avatar
Default air filter
I read on the forum about oil chance, now I need to know about airfilter change
Old Mar 16, 2009 | 08:44 PM
Default Re: airfilter
The Torx driver for the intake is a T-25 (don't know if that had been said).
Process:
1) Remove left and right intake tubes from airbox.
2) Remove airbox from engine (rubber grommets - just pull)
3) Turn airbox over remove 4 screws on each filter cover.
4) Replace filter in same orientation as OEM
5) Do steps 1-3 backwards.
Old Mar 24, 2009 | 07:08 AM
spensley's Avatar
Default Re: air filter
If you mean the cabin air filter then the above destructions will not help you at all - that's under/below the glove box.
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Sep 28, 2015 07:40 PM
