Interior padding console/door.
Old Nov 1, 2009 | 02:29 PM
velli's Avatar
Default Interior padding console/door.
Interior padding on console and driver side door/arm rest. I had noticed a post re: elbow pain/padding. I found the same problems w/my xf but did not want to change the appearance of the interior. I solved this problem by purchasing some gray microfiber and 1/2" dense foam padding. The console measurements are approx 4x13" (be sure to measure as this is only approx and I cannot remember the exact #'s). As you do not want to scratch the console, do not staple when finishing the project. I cut the microfiber to fit and secured it using "Gorilla Tape" (available at hardware stores etc). This type of tape is more sturdy than other tapes and will give some stability to the pad. After completing you can secure to the console using small velcro attachments on each corner.
I found that the door/armrest was a bit more difficult as you need to "sculpt" the padding to fit. When attaching this pad I used at least five small velcro pieces and placed these toward the inside of the door to increase stability.
The comfort is much improved at both sites and was very inexpensive, < $20.00 for all pieces w/plenty left over. Only issue is that you may want to use a small pieces near the cupholder as the console is set a bit far back . If you have a stick, or like to keep your hand on the shifter, the console pad may be too short.
Hope this helps.
Old Nov 1, 2009 | 02:51 PM
cmz's Avatar
cmz
Default Re: Interior padding console/door.
pics please thanks
Old Nov 1, 2009 | 03:24 PM
velli's Avatar
Will post pics soon.
V
Old Nov 1, 2009 | 07:06 PM
velli's Avatar
Pics posted.
Old Nov 8, 2009 | 09:14 AM
smfrycruzr's Avatar
My wife made this for my right elbow. Bought a piece of micro suede and embroidered the "Crossfire" logo, she also sewed in some padding. It uses stretch ribbon on the back, it slips over the consol door. Can be slipped off in a jiffy to be able to wash and keep it lookig nice.
Old Nov 9, 2009 | 07:07 PM
velli's Avatar
Looks nice. I actually changed my padding as I found that it was positioned too far back on the console. I made a very small pad and placed it over the cup holder; I find this works well as I usually have my hand on the shifter. May try making a pad similar to yours as it looks comfortable and I may be able to extend the entire pad beyond the cup holder with some modification.
v
Old Nov 10, 2009 | 01:34 PM
Would your wife at all be interested in making another one of those in black microfiber?? We can discuss compensation if she is interested
Looks great.
Old Nov 11, 2009 | 08:14 AM
smfrycruzr's Avatar
Sent you a PM
TerryR
Dec 13, 2019 03:27 PM
chturner
19
Oct 14, 2019 04:42 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
MiamiTVR
Other Cars Etc
Sep 29, 2015 05:27 PM
ritous1
Sep 26, 2015 01:27 PM
