map light flicker
Old Jun 25, 2010 | 04:19 PM
bearcats087's Avatar
Default map light flicker
the driver side map light flickers or doesnt even turn on sometimes when i press the button. does anyone else have this problem. (just replaced the bulbs too and still same problem)
Old Jun 25, 2010 | 07:00 PM
Default Re: map light flicker
Headlights and now map light flickering, is any other bulb flickering?
Do you have a bad battery connection or even a bad battery. Possibly the problem lies in the Illumination Module.
Old Jul 17, 2010 | 11:27 PM
alandx69's Avatar
The map console might be cracked like mines. I need to replace it but don't know where to get it. Any suggestions?
Thanks
Old Jul 18, 2010 | 12:08 AM
Same here in my '05 when I got it last year. Added a little solder to the lead on the bulb and it has acted ok since. I suspect the prongs/contacts in the socket were either dirty/pitted or worn to where they were not contacting the bulb well enough.
Could be the switch as well, but it wasn't in my case.
deerhunter
Jan 16, 2021 10:56 AM
xfireohio
Jul 20, 2020 12:03 AM
kaz1961
Mar 8, 2016 04:07 PM
xfClifford
27
Nov 10, 2015 10:08 PM
KwehCat
Jul 16, 2015 04:48 PM
