Where to grab power on driver side fuse box
Old Jul 27, 2011 | 03:58 PM
Sheldon's Avatar
Default Where to grab power on driver side fuse box
I looked at the fuses there and they all seem switched by the headlights, is there a fuse to pull from that has power when the car is on?
Or a better place inside the cabin to grab power?
Old Jul 27, 2011 | 04:07 PM
ImportLabSRT's Avatar
Default Re: Where to grab power on driver side fuse box
Under the hood, all the way in the back of the main fuse box on the drivers side, is a terminal that has switch B+. I use that for everything. To be on the safe side, I added a 20amp fuse right at the terminal (similar to the write up on here for i/c pump all the time).
~edit~ to get to that terminal you have to take the upper fuse box cover off. Just pull the 4 tabs away from the lower box and lift up.
Old Jul 28, 2011 | 09:53 AM
joejones's Avatar
Try #4. There is where I have my RD connected. It is switched.
Old Jul 28, 2011 | 09:58 AM
NeedsWings's Avatar
Rudy made up this image a while back...
BrenLW
Aug 5, 2015 04:53 AM
michaelcycle58
Jul 28, 2015 08:12 PM
ricardo 53
Jul 21, 2015 07:49 AM
waldig
Jul 20, 2015 08:10 AM
ZX2 Nick
Jul 15, 2015 08:49 PM
