Airbag and clock spring
Old Nov 7, 2011 | 06:55 PM
herronn1995's Avatar
Default Airbag and clock spring
I just got done replacing my clock spring that had bent and broke inside the steering wheel and got everything back together but the airbag light will not go off after everything is running?
Any suggestions or cures?
Old Nov 7, 2011 | 07:14 PM
32krazy!'s Avatar
Default Re: Airbag and clock spring
has to be reset at the dealer thru star das
Old Nov 7, 2011 | 07:46 PM
What if I unplugged the battery for like a day would that reset the gauge's and possibly turn the light off because I really don't want to pay the dealer of I can do it myself
Old Nov 7, 2011 | 07:54 PM
32krazy!'s Avatar
if you could do itn yourself i would have said so. srs /airbag lites have to be reset using star das. unless you have this software, the mutiplexer cable and associated hardware you have to go to a dealer
Old Nov 7, 2011 | 07:58 PM
Alright thanks we'll take over to the dealer this weekend and get that taken care of
Thanks
Old Nov 8, 2011 | 07:15 AM
PAULW's Avatar
Just a thought but have you driven it, while driving is the light coming on and then going off? I know a guy who had his steering wheel off and after he re-installed it his light was going on and off so he called to ask if my shop's star machine would work on our cars. I talked to one of our MB tech's (Sprinter) and he advised him to unbolt the airbag without unplugging it and make sure the plug was secure and after he did that his car was fine, maybe the plug wasn't tight. I know if you start the car with it unplugged it takes a star machine to clear it but you might try checking the plug.
Old Nov 8, 2011 | 07:36 AM
That would probaly work only we started the car with the airbag unplugged because we had to realign the steering after getting to the clock spring. I will just have it taken to the dealer. Thanks though for the suggestion
Old Nov 8, 2011 | 08:30 AM
PAULW's Avatar
Yep, it has to go to a shop with a Star machine.
2005 Ragtop
Oct 3, 2015 03:01 PM
suelo
Sep 18, 2015 05:01 PM
ayebb
Sep 18, 2015 03:35 PM
westonrose
U.K.
Sep 16, 2015 02:22 PM
stlas69
Sep 14, 2015 07:37 PM
