Clicking valve under the glove compartment
Old Apr 17, 2014 | 09:45 PM
Philco's Avatar
Default Re: Clicking valve under the glove compartment
I've had this same problem myself for many years. At first I thought it was coming from the glove box itself. But I couldn't pinpoint the problem. In the end, I just learnt to ignore it.
Old Apr 17, 2014 | 10:20 PM
tageier's Avatar
Replaced the ac/heater control unit (the main one in the center console above the radio) and it fixed it.
Old Apr 17, 2014 | 10:56 PM
Philco's Avatar
Maybe I'll try that if the noise starts getting on my nerves again. Thanks
Old Apr 17, 2014 | 11:04 PM
tageier's Avatar
Wasn't so much as the noise as the unit wasn't controlling the fan speed properly...
Old Apr 17, 2014 | 11:40 PM
Indelibility's Avatar
Blower motor, and don't buy a cheap one...trust me.
Old Apr 18, 2014 | 09:09 AM
Thornh's Avatar
OK so I have had the same problem(s) for quite a while now, clicking from near the glove box and erratic heater/ac fan speed. Have replaced the resistor, no fix. any consensus on which of the two parts mentioned here will fix it (blower motor or control unit)? I really don't want to throw good money after bad since these parts aren't inexpensive...
Old May 17, 2014 | 11:35 AM
Thornh's Avatar
I have replaced the heater/AC control unit in the center stack, and have had no issues with erratic fan speeds, or clicking noises from around the glove box since.
Old May 17, 2014 | 02:11 PM
Philco's Avatar
Interesting. Exactly what part did you replace ? Got any pics ? Cos my own noise is starting to get on my nerves again.
Old May 17, 2014 | 09:44 PM
Thornh's Avatar
Default
It's the control unit in the dash with the adjustment ***** for temperature fan speed and outlet selection.
Old May 18, 2014 | 04:07 AM
Philco's Avatar
Thanks, I'll look into that. I can't help feeling it's something else though. Much of the noise seems to be coming from the glove box area. There's no problem when you're driving on a smooth road, but once you hit a rough patch the rattling goes berserk. It's perplexed me for years now.
Old May 18, 2014 | 07:54 AM
Thornh's Avatar
If it sounds more like a rattle than a relay clicking on and off rapidly, it may indeed be something else. If you purchase a new control unit they are quite expensive, but if you can get one used it should be less expensive should you decide to go that route.
syfi
Mar 28, 2026 04:14 PM
Billy22Bob
Sep 26, 2015 10:16 PM
toob
Sep 26, 2015 11:44 AM
maxcichon
Sep 25, 2015 02:55 PM
RacerXofFL
Sep 15, 2015 05:00 PM
