Steering adjustment
Old Oct 4, 2019 | 09:54 PM
Moparboy's Avatar
Default Steering adjustment
Does anyone find that steering wheel is to high? I know it is telescopic but i need something lower. I drive all of my cars in the lowest position of the steering. Does anyones try modification on that steering: tilt steering kit from.... or adaptation from a donor car
Old Oct 4, 2019 | 10:06 PM
Default Re: Steering ajustment
Nope. I've read most all the threads here since 2011 and never any mention of that.
Old Oct 4, 2019 | 11:12 PM
Only way I know of, is to set the seat higher. If that isn't workable I have no suggestions left. Good luck! ;(
Old Oct 4, 2019 | 11:23 PM
Speaking of that, I found that doing so really helps around sunset when the sun is straight out the driver's window.
Since you can't rotate the visor, the only other choice is to block the sun with your hand.
BUT !
If you raise the seat way up till your head hits the top, then the sun is out of your eyes
Old Oct 5, 2019 | 07:58 AM
UrbanE's Avatar
I too would prefer tilt, as well as telescopic. Unfortunately I don’t think I’ll ever see that offered as a mod.
you just get used to it.
Old May 16, 2022 | 04:36 PM
Hawker's Avatar
Default Re: Steering adjustment
I know this is an older thread....but this is the primary reason I decided not to buy a Crossfire last year. I'm 5'5" and found that I just couldn't get comfortable behind the steering wheel.
It's really too bad they didn't include this adjustment....particularly because this option is not exactly high tech or expensive and has been around for a long time. Strange?
Old May 16, 2022 | 04:42 PM
There is always a thick pad on the seat bottom?
MB Star
Dec 23, 2019 08:12 PM
JimmyG
Feb 28, 2018 11:16 PM
MrMoPar
Aug 24, 2013 05:30 AM
FUBU
Sep 5, 2012 08:42 PM
X-Feuer
Jun 30, 2012 03:47 PM
