power window
Old Feb 4, 2022 | 05:43 PM
atime's Avatar
Default power window
I am buying a Crossfire with a broken pw switch. It has fallen thru the mount, is this a difficult fix? The switch is cheap on line, I just have no idea how to access it. Any help is appreciated.
Thanks
Old Feb 4, 2022 | 05:51 PM
Default Re: power window
Not a big deal but you will have to remove the center console. I believe there is a video on U-tube.
Old Feb 5, 2022 | 11:36 AM
all u have to do is with a plastic prier like a plastic putty knife pry up the ring raised up section around the shifter , then pry up the part that goer around the shifter,, then pry up the section where the switches are located ,, dis connect elect. then see where it is cracked or broken clip that holds the sw in .. get Q-bond to glue it back together Q-bond is on ebay jim
blackpepper
Oct 24, 2018 06:56 PM
Futureknows
Sep 9, 2014 11:25 AM
Chadders
Sep 7, 2012 07:22 PM
ghostface157
Aug 24, 2009 10:51 PM
Aknester
Jul 7, 2008 02:50 AM
