Cupholder Replacement/Improvised Fix
Old Jun 17, 2024 | 03:45 PM
civil_wrongz's Avatar
Question Cupholder Replacement/Improvised Fix
A minor inconvenience when I bought the car was that the only cupholder inside was broken; I didn't mind because I only use resealable bottles in the car. The replacement part is way too expensive in my opinion and I don't want to risk damaging other components around the cupholder. Some Ebay substitute cupholders don't look compatible with the Crossfire and I want to avoid unnecessary problems. Does anyone have a simple fix, such as making a cupholder out of clamps or using materials to make one from scratch that would fit into the cupholder slot? I understand this is an unusual request but I'd appreciate the feedback.
Thanks.
Old Jun 17, 2024 | 06:17 PM
Nelson G's Avatar
Default Re: Cupholder Replacement/Improvised Fix
I ended up using an Audi TT cup holder and putting it between the seats. It's not an easy reach, but I am usually with my wife. This was not my idea I saw another user but he placed it on the passenger side of the center console.
Old Jun 18, 2024 | 01:17 AM
Thanks.
Here's a link to a dual cup holder that I made. You would replace your broken one with the storage bin that you can get off e bay. I'm not selling it, just showing how you can build it.
Dual Cup Holder
Old Jun 18, 2024 | 10:13 AM
dcskmail's Avatar
Here's another alternative goes into the console : email Leonard Rynes rynes@icloud.com
Leonard Rynes still makes the cup holder. The cost is $55-$65 shipped depending on the one you want.
Old May 12, 2025 | 10:26 AM
type dougie's Avatar
How did you mount this?
Old May 12, 2025 | 09:41 PM
Which one are you asking about?
Old May 13, 2025 | 07:44 AM
the audi tt one on the back wall
Old May 13, 2025 | 01:49 PM
Nelson G's Avatar
I used some flat aluminum and took the cup holder apart and used a screw through the bottom and drilled a hole in the flat aluminum. Then I lined up the dog leg of the aluminum and drilled the holes through the aluminum, the plastic cover into the bulkhead. Then I used a self-tapping screw to attach it to the bulkhead.
If you go this way make sure all the parts are there when you purchase one. I came across a lot that was missing pieces and the rubber at the bottom of the cup holder was cracked.
Nelson
Old May 13, 2025 | 04:57 PM
And don't forget, the fuel tank is behind that bulkhead.
maxcichon
Sep 28, 2015 07:34 AM
rakoom2002
Aug 24, 2010 06:18 PM
j-fire
Feb 12, 2009 11:37 PM
NJspeed69
Aug 26, 2004 11:11 AM
pelked1
Aug 22, 2004 03:22 PM
